Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 02-18-2012, 04:40 PM
putts putts is offline
Vehicle: 1994 Dodge Ram
putts is on a distinguished road
Default Tow hooks, D-Ring shackles. What do I need?
I'm looking to add tow hook to my 1994 Dodge RAM 1500. I've done all sorts of searching for bolt on d-rings and have found virtually nothing.
I thing I'm looking for rings that have a plate that mounts to the frame (obviously) and then just has a shackle that hangs off of it. That way the shackle/D-ring can be removed when not necessary (always fun to have on there, I know BUT, I want a shackle, not a permanent mount "hook" or Loop/ring)
A couple years back I found exactly what I was looking for but passed up for some odd reason and now I can't find them. I don't imagine they are THAT difficult to get but I sure can't find them!
Second option is to add a full-blown hitch to the front but I don't *really* want to shell out that kind of money when all I really want are several recovery options for being stuck in a multitude of precarious positions!
Also, I do not weld (don't know how) and, for all intents and purposes, I'm not much of an automotive guy. Not even shade-tree mechanic stature, but I've installed "bolt-on" hitches in the past with much success so I don't thing D-rings would be all that different. Maybe a bit easier even? Thanks for the input!
Old 02-26-2012, 12:19 PM
dezertrunner dezertrunner is offline
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
dezertrunner is on a distinguished road
You won't find anything bolt on that's worth a damn. Bolts on's are typically garbage anyways. Just weld a pair of tabs to the frame and put drings in when you need them. That's what I did.
