wont start - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 02-18-2012, 09:32 PM
black beast black beast is offline
Vehicle: 2000 dodge ram 1500
black beast is on a distinguished road
Default wont start
i was driving down the road yesterday and my truck died on me. out it in neutral and it started up but killed right away. got it home thinking it was fuel pump but have plenty of fuel pressure to the fuel rail. right around 48 or so. tried switching the brain box with my dads truck since it is the same exact truck but would not work. dad said he cranked the truck for one minute and than pulled a plug and it was dry. i dont know what my problem could be. please help
Old 02-22-2012, 11:02 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Put your box back in, as I have heard the box is programmed for the specific motor in your truck ( if you ever switch motors you have to have the box from the donor as well ) Check to see if you are getting spark from the coil, fuel... check your fuses and relays for the injectors if no fuel and you have fuel pressure. Only other thing that would be the issue if all that checks out good is the crankshaft position sensor.
I Am Groot !
