Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 02-19-2012, 12:03 AM
Liredneck Liredneck is offline
Vehicle: 2009 1500
Trim Level: TRX4
Rep:15
Liredneck is on a distinguished road
Default Heat only works when on the gas ?
Hi I have a love / hate thing with my truck lately . Seams every time I turn around something else is not working . Lately my heat only works when I'm moving and on the gas , the defrost has never worked and don't get me started with the windows,speakers , tail lights ect.
So why does my heat only work when Im moving and on the gas. It blows real hot unless I stop or let of the gas the. It feels like the ac is on . It's 20 outside and I'm sick of it
Old 02-19-2012, 12:13 AM
Dodge891's Avatar
Dodge891 Dodge891 is offline
Vehicle: 2001 dodge ram
Trim Level: Single cab short bed
Color: Vader Black
Rep:48
Dodge891 is on a distinguished road
I have them same problem with my heater, but it just started recently doing it
Sparky says RAM IT
Old 02-19-2012, 12:14 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1276
Back flush the heater core! I had that very problem with my old Dakota. Did a back flush and she pumped out the heat like no tomorrow.
Big Red my old 2011 Sport
Old 02-20-2012, 10:19 PM
Vehicle: 2009 1500
Trim Level: TRX4
Rep:15
I just put a new heater core in , do you think it could of clogged in a few months? and its 20 degrees out so ive turned off my outside hoses. could i just reverse the lines and let it pump itself out ?
Old 02-21-2012, 09:56 PM
darcylee79 darcylee79 is offline
Vehicle: 1987 Dodge Power Ram
Trim Level: Power Ram
Color: Green
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
darcylee79 is on a distinguished road
Check the coolant level and make sure it is up and full. I know it sounds crazy but will not blow heat unless full and will not over heat because it is cold enough outside. If its down check for leaks, check heater core and more likely the thermostat would go first.
Old 02-22-2012, 03:03 PM
Vehicle: 2009 1500
Trim Level: TRX4
Rep:15
Thanks man it was the coolaint level. I was down almost two gallons , i just had the heater core replaced so that was the last thing i thought it would be and was so worried with all the blend door issues lol
Thanks again i have heat !!!!!
Old 02-22-2012, 03:09 PM
jjz28's Avatar
jjz28 jjz28 is offline
Vehicle: 2007 1500 4.7
Trim Level: SLT TRX4 Offroad
Color: grey
jjz28 is on a distinguished road
I have had this happen on several different cars. I would say you have air in the system. You can bleed it if it has the bleed screws, you can also burp it with the hoses (with the cap off squeeze the hoses real fast to get any air out. Sometimes you have to lift the front of the car up too, or park it on an incline. I am sure you have air or not enough coolant in your system.
jjz28's Avatar
Color: grey
oops, didnt see the last post! DUH!
Old 02-23-2012, 02:19 PM
THK THK is offline
Vehicle: 02 Dodge Ram
THK is on a distinguished road
Why 2 gallons down? I would be looking for a leak or possible lead hgasket leak. That much of a fluid loss indicates a problem.
