Performance roller lifter - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Old 02-19-2012, 03:43 PM
Waylon80's Avatar
Waylon80 Waylon80 is offline
Vehicle: 2005 Dodge Ram
Color: Mango Tango From House Of Kolors
Waylon80 is on a distinguished road
Default Performance roller lifter
Hey I got a lifter that's pecking so I want to replace all of them at once and wondering if theres a better set than the stock ones that will gain better performance than stock without having to make any changes to my engine, so a simple pull the old ones and replace with newer ones. If anyone can help me with this problem would be great thanks
"THE ENEMY OF YOUR ENEMY IS YOUR BEST FRIEND"
Old 02-19-2012, 08:18 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
If you are looking at using roller lifters, you will have to get a camshaft to work with them. If you already have roller lifters, I don't believe they are factory. I am not aware of the 5.9 coming factory with a roller cam/lifters.
brad
Interested in one of my mods?
Old 02-19-2012, 09:05 PM
Brutus's Avatar
Brutus Brutus is offline
Vehicle: 2006 Dodge Ram
Trim Level: 4x4 Quad Cab Sport
Color: Mineral Gray
Rep:86
Brutus will become famous soon enough
the Magnum V8's have hyd roller lifters/cam.
just get the Mopar lifters. be sure to prime them before you fire it up.
2006 Hemi Ram QC 4x4
2000 AF RC Dak R/T
2000 BW CC Dak R/T
Old 02-19-2012, 10:59 PM
Waylon80's Avatar
Are there any that are better than stock and I believe what's in it is factory
Old 02-19-2012, 11:16 PM
tuckertrucker's Avatar
tuckertrucker tuckertrucker is offline
Rep:34
tuckertrucker is on a distinguished road
check out harland sharp you can get a 1.7 ratio roller rocker rocker non-adjustible no other mods required pull the old bolt on the new torque to speck. Your 5.9 should have a roller cam stock, roller lifters stock but the rockers are non roller 1.6 ratio i do believe. My 2 cents
tuckertrucker
1995 1500 4x4 360 3in lift 33 tires Magnaflow Gibson shorties Spectre CAI modded keg 52mm tb.
Old 02-19-2012, 11:26 PM
Waylon80's Avatar
Yeah I heard about that thinking about doing that after I get new lifters I heard comp makes good lifters
Old 02-20-2012, 12:18 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
The 360/5.9 has had roller cam/lifters since the late 80's.
CompCams has a nice set. The main advantages are tighter clearances and better plunger and oil control, which comes into play at higher rpm's.
Old 02-20-2012, 12:31 AM
Waylon80's Avatar
Ok well I have to have new lifters and would Like to get a bigger cam cause I love the way they sound and heard they gain hp to I know I can get a cam kit with cam and lifters but I don't know the right one to pick spec wise
Old 02-20-2012, 12:38 AM
Waylon80's Avatar
Whats the biggest cam I can get without having to totally redo my motor for it to work and are hydraulic roller lifters the same as roller lifters
Old 02-20-2012, 02:14 AM
Rep:99
There are solid lifters and hydraulic lifters. They are available in flat or roller configuration. Hydraulic is best for street applications, they self-adjust. Solids are better for all-out racing. They require manual adjustments periodically. It's not as big a problem with rollers as flats because the flats wear more, but unless you want to be under the hood fairly often, stick with the hydraulics. As for a cam, the biggest you can get isn't the best you can get. The engine will handle a lot more cam than the stock computer will run. You mentioned the way they sound. I suppose that means the rumpity-rump variety. This is not friendly with the stock computer. You'll need aftermarket programming to handle that sort of cam. I'd go with the CompCams Xtreme Energy XR264. You will need the matching valves springs with any cam upgrade. It'll work well with a 5.9's stock systems. Any hotter and you'd need computer mods.
1997 dodge ram sport
