Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
tonneaucovered.com
Old 02-19-2012, 06:52 PM
blacklaramie98 blacklaramie98 is offline
Vehicle: 1998 dodge ram
Trim Level: SLT laramie
Rep:12
blacklaramie98 is on a distinguished road
Default Paint and body help!
My hood had only one bad spot on it where I first thought it was bird poop. After washing it today I noticed I had many more and I want to fix them from spreading. Also I have some problems on the cab of my truck, top off my tailgate, fender and below my drivers window. If anybody would give me some info on how to fix it i would appreciate it
Old 02-19-2012, 07:52 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Looks like the clear coat is lifting. The UV rays go through the clear coat, reflect off the paint, and can't reflect back through the clear.
The only way I've found to make it look better is to 600 wet sand it careful not to go through the paint. Then you can clear coat it again. It's not sure fire and takes some time, but usually looks better.
Old 02-19-2012, 11:11 PM
Rep:12
Ok I will have to try it when I get a chance. Where should I buy the clearcoat at? Thanks in advance
Old 02-20-2012, 02:55 PM
HighFive5 HighFive5 is offline
Vehicle: 1997 Ram 1500
Trim Level: 1500
HighFive5 is on a distinguished road
any local autobody supply store.
Old 02-22-2012, 01:00 AM
FireSlayer's Avatar
FireSlayer FireSlayer is offline
Vehicle: 2001 Dodge Ram 1500
Color: Maroon
Rep:39
FireSlayer is on a distinguished road
You can buy it at any vip normally, but I would recommend a professionals opinion on it. certain clear coats wont stick well to your paint. sometimes at the good auto paint stores they have someone who knows what they are talking about, I would go check it out before you do something you'll regret.
Remember it doesnt hurt to ask, its the only way to learn
"Courage is the resistance to fear, the mastery of fear, not the lack of fear." Mark Twain
Old 03-05-2012, 09:38 PM
Dykes92's Avatar
Dykes92 Dykes92 is offline
Vehicle: 1997 Dodge Ram1500
Color: red
Dykes92 is on a distinguished road
I had the same problem in all of the same spots. I striped the paint to metal, finished it with 180, primed it with epoxy primer, 320 blocked it, and reprimed. It took about 10 hours.
Old 03-12-2012, 09:55 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
Looks like you need to have the whole panel painted.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 03-13-2012, 11:26 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Bought my truck with the same and rust... this was start to finnish. My buddy, a professional painter did the work ( I helped some) but he said even if you fix the spots the rest will peel shortly, better off stripping it with aircraft stripper and sand with 320 epoxy prime and sand with 600 and paint. If you dont want to use 2 stage (base /clear) you can use a single stage urethane. Shops will run you $4000 to strip and paint or you can do the work and have it painted cheaper around $1000-$1500
Mike
Old 03-21-2012, 06:23 PM
Rep:12
okay sorry i havent been on in awhile but appreciate the input on the subject but i still have questions. so i shouldnt just sand the spots down and shoot some clear coat on it? it sounds like the easier way and i havent really got it anywhere else besides those spots so sanding it down i would think would keep it from spreading and i would probably go a little beyond to ensure i get it. another is what is a good autobody supplier to get supplies to do this. im going to end up repainting stuff because i am going to get a new tail gate because mine is dented to shit so what kind of paint should i get? thanks
Old 03-21-2012, 09:51 PM
sonocativo's Avatar
Rep:215
The thing about clearcoat is, it has to seal, if you just feather edge it the edges are actually open and the edges will start to peel...it wont last long and you will be back to square one in a year or so. If you clear the whole panel/hood/tailgate/ect... it will take but just doing spots it will look bad as the rest of the clear is older. It is really up to you as far as how much work/time/money you want to put into it and how you want it to look. It is possible to fix the spots and clear the entire truck without painting the entire truck, but you have to take your time sanding/feathering it out so the clear goes on smooth and the entire truck looks good, you want the clear to have a good bond so it doesnt peel/chip and look like crap shortly afterwards.
Mike
