Old 02-19-2012, 08:05 PM
dig dig is offline
Vehicle: 2010 1500 Dodge Ram Crew Cab
Trim Level: SLT- Big Horn
Rep:25
dig is on a distinguished road
Default Air Lift
Well Tue evening we are going to install the air lift 1000 air bags and the Wirelessone compressor system on my 2010 Ram Big Horn. Going to do it at my buddies shop, he has a lift, I think that will make it easier then over my pit.
Old 02-20-2012, 11:39 AM
Ramajama's Avatar
Ramajama Ramajama is offline
Vehicle: 2014 RAM 1500 R/T
Trim Level: R/T Sport
Rep:27
Ramajama is on a distinguished road
Good luck! I am intrested in hearing the results.
2014 RAM 1500 R/T
2015 RAM 1500 OUTDOORSMAN 4X4
Old 02-20-2012, 07:55 PM
B.Hud B.Hud is offline
Vehicle: 2009 ram
B.Hud is on a distinguished road
x2 i think im going to order mine tonight but minus the compressor
Old 02-20-2012, 10:26 PM
wvu dodge wvu dodge is offline
Vehicle: 2010 Dodge 1/2 ton
wvu dodge is on a distinguished road
You shouldn't have any problems with the install, the garage lift will surely speed things up. I installed this about 3-4 months ago. Just jack up the frame and let the suspension droop, and stuff the air bags in the springs. Then route the air lines to your preferred spot.
I spent the majority of my time deciding and routing the air lines. This was the best improvement I have made so far. If you've ever hauled or towed anything that made you disappointed by the ride height when loaded, you can't go wrong for the price of these bags.
I just hauled 5k lbs of gravel on a 2300 lb trailer with the bags pumped up to 33 psi and it looked like the stock ride height. I leave the bags aired up to above 30psi all the time and the rear susp is a little stiff but I'm coming from a 3/4 ton so its no different really. With them aired up I get some axle hop at times if the potholes and my rate of acceleration are just right.
I thought about getting a level kit because i got 7/8" lift at the rear hitch with them aired up empty, but decided to leave it sit at stock height. I think a person that tows regularly with these bags could get away with a level kit though, without looking like the headlights are pointed at the sky.
Old 02-21-2012, 10:24 AM
Ramajama's Avatar
Rep:27
I spent the majority of my time deciding and routing the air lines. This was the best improvement I have made so far. If you've ever hauled or towed anything that made you disappointed by the ride height when loaded, you can't go wrong for the price of these bags..
That sounds simple enough.
2014 RAM 1500 R/T
Old 02-22-2012, 10:47 PM
dig dig is offline
Rep:25
Default Air Lift
Well it's in and all went well. It still took around 4hours. We mounted the compressor and the sensor under the back seat out of the weather.
Old 02-25-2012, 06:17 PM
5.7ram's Avatar
5.7ram 5.7ram is offline
Vehicle: 2010
5.7ram is on a distinguished road
Let see some pics Dig. Did you take any?
2011 Dodge Ram CC Sport Hemi. / 4300 Hid's Top & Bottom / Tints / 24' Kmc Slide's w Toyo's / BellTech 2/4.
Old 03-05-2012, 10:28 AM
Ramajama's Avatar
Rep:27
What he said....
2014 RAM 1500 R/T
Old 03-08-2012, 11:13 AM
Huka42's Avatar
Huka42 Huka42 is offline
Vehicle: 2009 Dodge Ram 1500
Huka42 is on a distinguished road
Every winter I leave about 500 lbs of sand in the bed above the axles. Would the AL work well in my case? Or will the ride be too stiff. I do have a 2/4 lowering kit on it.
