tonneaucovered.com
Old 04-03-2012, 08:11 PM
jagman1995's Avatar
jagman1995 jagman1995 is offline
Vehicle: 2011 ram 1500slt
Color: blue
jagman1995 is on a distinguished road
Send a message via Skype™ to jagman1995
Default 2011 radio removal
I have a 2011 ram and need to change the radio. All of the ways that are shown are models with the center console. I have the bench seat. Are the 2 screws in the top the only ones or are there other ones? Thanks
Old 04-04-2012, 01:06 AM
shostopper17's Avatar
shostopper17 shostopper17 is offline
Vehicle: 2011 Dodge Ram Express
Trim Level: 1500 Express
Rep:54
shostopper17 will become famous soon enough
this should help it helped out with my 2011
http://youtu.be/aBE6AbNu86k
Old 04-04-2012, 01:28 AM
Rep:2720
I believe that you will find 2 more screws down by your cup holders or ash tray
Old 04-04-2012, 06:44 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
There are only the two screws at the top on mine. After removing the screws you just pull and the frame unclips from the main part of the dash.
Old 04-04-2012, 03:56 PM
jagman1995's Avatar
Color: blue
Great thanks I will let yall know how it goes and send some pictures. Thanks
Old 04-04-2012, 06:28 PM
Hex's Avatar
Hex Hex is offline
Vehicle: 2011 Ram 1500
Rep:30
Hex is on a distinguished road
On mine there was another screw just above the 110v plug. I used a small flathead screwdriver to pry off the black plastic that surrounds the plug and there is a small screw. I can't remember if it's a phillips head or a T20 star head.
Old 04-05-2012, 11:54 AM
Rep:30
jagman, I didn't notice your trim level. Yes, you will have the screw near the 110 VAC outlet. I keep forgetting SLTs are available with bench seats. They are like hen's teeth around here and I didn't even know they existed when I bought my truck or I would have looked harder.
Old 04-06-2012, 10:10 AM
vtelvr's Avatar
vtelvr vtelvr is offline
Vehicle: 2011 Ram Express
Trim Level: Express 1500
vtelvr is on a distinguished road
Yep, two screws at the top, and a slight tug will gain you access to the radio, unless you have the 110outlet. If so, then be careful, as I don't know if there is an extra fastener there. Good luck!
Old 04-06-2012, 06:23 PM
Hex's Avatar
Hex Hex is offline
Rep:30
There is a screw behind the black plastic the surrounds the 110v plug. Just use a small screw driver to pry off the black that surrounds the plug and you'll see the third screw. After that it's a good tug and you're golden.
Old 04-13-2012, 07:52 PM
jagman1995's Avatar
Color: blue
Thanks Guys, that's all it was was the 2 screws. I made a video if some one else needs it . it took about1-1/2 minutes to remove the radio.
