Old 02-20-2012, 02:49 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
Default Lets talk, Tire SIZE-vs-PERFORMANCE
I am looking at new tires in the near future. I have a 4th gen 2wd QC and it will have a 2/4 drop kit on it next week. I want a wider tire and I have been reading that a 305 series tire wont fit up front due to rubbing. well i am not looking at going any taller but just wider. all the tires i have seen in a 20" option are shorter and maybe a half inch wider for it to be able to fit up front. the difference is about 1 inch shorter than stock. I know i have had trucks with taller tires before and noticed the decrease in performance.
So, what can I expect performance wise by going to an inch shorter tire?
also I am thinking about running a 275/55 or a 285/55 up front and a 305/55 or 305/50 in the rear. anybody running two different tire sizes F/R?
Old 02-20-2012, 07:27 PM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
Changing tire height affects the truck in a similar means to changing gearing ratios. Smaller diameter will provide better acceleration at the expense of top speed, which won't really matter since the truck has a speed limiter anyways.
Running different widths of tires front to back limits your ability to rotate tires if they have a directional tread pattern.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
Old 02-20-2012, 08:25 PM
Ramfd's Avatar
Rep:150
thats kind of what i was thinking with the tire size. is there a general rule of how much of a change is acceptable?
Old 02-20-2012, 09:49 PM
moparornocar72's Avatar
Rep:630
another problem with going with two different size tires is the fact u won't be able to rotate them except side to side.
14.268 @ 95 MPH Full Trim
