Old 02-20-2012, 02:06 PM
Ramathorne Ramathorne is offline
Vehicle: 2013 Dodge Ram 1500 Quad Cab
Color: Mineral Gray
Rep:48
Ramathorne is on a distinguished road
Default Sonnax 545RFE Line Booster
I Have 2 To Sell
$40 Each
Free Shipping
The 45/545RFE transmission uses a full range line pressure sensor mounted on the outside of the transmission for "closed loop" line pressure control. Due to this system, traditional methods of raising line pressure by changing the PR spring or valves have no effect. The Sonnax Line Pressure Booster alters the pressure signal sent to the computer causing the computer to raise line pressure has 15-30 psi increase. Higher line pressure increases clutch holding power and torque capacity but with these transmissions, the increase has a limited effect on shift feel. Changes in shift feel will be noticed mostly under aggressive driving or loaded conditions. This part is ideal for heavy duty and modified vehicles and even stock transmissions when a little extra pressure is desired. No other modifications are required. The Line Pressure Booster installs between the pressure sensor and vehicle harness using OEM style sealed connectors. Simply unplug the vehicle harness and reconnect with one of these parts.
Old 02-20-2012, 03:55 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Will that booster work with a 2003 4.7 auto?
Thanks
Old 02-21-2012, 08:43 AM
Color: Mineral Gray
Rep:48
Hey I am not sure
You would have to check out what kind of tranny is in your truck
Thanks
Old 02-21-2012, 06:35 PM
Color: Mineral Gray
Rep:48
1 sold...1 left
Old 02-23-2012, 08:40 AM
Color: Mineral Gray
Rep:48
SOLD....
Thanks Guys
