Old 02-20-2012, 04:29 PM
lascaster lascaster is offline
Vehicle: 1995 Dodge Ram
Color: Blue
lascaster is on a distinguished road
Default 1.7 rockers with my cam?
hey guys, im in the process of putting my engine back together and am considering throwing in some harland sharp 1.7 rockers. The problem is, i dont know if I can get away with it because I have a mild cam for the truck.
heres the cam specs.
Lift .458 INT
.467 EXH
Duration 260/264
Overlap 55
Centerline 109
its mopar performance part number 5249549
I am also wondering if Ill need new valve springs with this setup?
the cam was given to me for free so I cant beat it. just looking o see if I can get a bit more while Im at it.
Thanks guys
Old 02-20-2012, 07:37 PM
tuckertrucker's Avatar
tuckertrucker tuckertrucker is offline
Rep:34
tuckertrucker is on a distinguished road
I am not sure You already have the lift with the cam, with the 1.7rr you will be lifting them more. Shorter push rods may work, BUT again bad idea. You can get 1.6 rr from HS also. I would really do some research on this before you install the cam and the 1.7rr. One thing I do know is that you can install the 1.7rr with the stock cam no prob, The 1.7s gives you lift and makes the computer see a bigger cam.
1995 1500 4x4 360 3in lift 33 tires Magnaflow Gibson shorties Spectre CAI modded keg 52mm tb.
Old 02-20-2012, 09:38 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
That's gonna put you at .486/.496 lift numbers. You can do it. You will definitely need better than stock springs. Pop for better locks and retainers too.
Old 02-24-2012, 03:11 AM
dodgeman2289 dodgeman2289 is offline
Vehicle: 97 ram 1500 ss/t 5.9
Trim Level: ss/t
Color: sunset burnt orange
Rep:44
dodgeman2289 is on a distinguished road
id be interested in buying that cam.. i have 1.7s on stock cam wrks great but im looking for mild cam to throw in my rig when i add the 3.92 gears m1 intake manafold and 2600 stall converter.
spectre cold air,sct tuner,ported tb,msdblaster coil,1.7 roller rockers,u/d pulley,180 stat,tranny cooler,transgo tfod-hd2 shift kit,pacesetter headers,cat delete,flowmaster super 10
