Old 02-20-2012, 06:59 PM
11 Express 11 Express is offline
Vehicle: 2011 Ram 1500
11 Express is on a distinguished road
Default Dyno Problems on 2011 Express
Tried to dyno my truck this weekend but ran into a few problems. First run was in 3rd gear with traction control off but smoked the rear brakes/traction control?? We had alot of smoke coming from passenger rear tire area and smelt like brakes burning. It only put down 183 on that run. Second run we put it in 4th gear and got 238 but same smoke and burning smell. What are we doing wrong and why wont my traction control completely disable? Wanting to run it again but dont want to be disappointed again. For the ones who have successfully dyno'd their trucks what did you do that I'm not? Thanks
Old 02-20-2012, 08:31 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
From everything I've seen on this forum, just switching off the traction control button doesn't totally disable the traction control. Allegedly there is always some inherent TC...just not as aggessive. This sounds like what's happening here. There must be some slippage on the roller or something like it going on perhaps.
Old 02-20-2012, 08:43 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Pull the ABS fuse to competely disable all traction aids
You still can't beat the 105 mph limiter, so you probably won't get a full pull in third!
Old 02-22-2012, 05:01 AM
Hedghawg71's Avatar
Hedghawg71 Hedghawg71 is offline
Vehicle: 2011 Dodge Ram Express
Rep:21
Hedghawg71 is on a distinguished road
I am putting a Toggle/switch fuse link (redneck engineered of course) on that one... We can't have that crap going on when I wanna haul booty!
Nothing a Hammer can't fix!
Old 02-22-2012, 09:02 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Like said above, you can't completely disable the traction control with the button on the dash, only partially.
I'd assume the sensors/pcm was freaking out because your rear wheels were moving and your front wheels weren't so it was trying to apply brakes to the rear to slow them down. I was going to suggest disconnecting the front wheels sensors but disabling the traction control via removing the ABS fuse sounds like a better and easier idea...
Sean
Old 02-22-2012, 09:13 AM
EVS1's Avatar
EVS1 EVS1 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:12
EVS1 is on a distinguished road
According the the NAV system, mine maxed out at 109, is that much variance normal?
Old 02-22-2012, 10:47 AM
TNC TNC is offline
Rep:12
Since it was your GPS giving that reading, it's probably fairly accurate. Since that governed speed isn't a legal mandate, it probably doesn't have to be exact. Also the speed might vary a bit because of drive gear ratios, tire size, and other subtle factors in the truck. It's a shame to some degree that Dodge does something like this.
Old 02-22-2012, 11:09 AM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
We had to pull the fuse when we had the Charger done at the LX nationals. in fact when we got her up on the sled that is the first thing the guy did when hooking us up.
BTW how much is your shop charging ?
Old 02-22-2012, 04:13 PM
thanks for all the suggestions..I go back in 2 weeks so Ill have him pull the fuse and see what we get..he is only charging me 50 bucks to dyno if everything goes good..didnt charge me anything this last time because we had so many problems..also forgot to mention that my torque converter didnt lock until 3100 rpm then unlocked at 3400..
Old 02-22-2012, 04:21 PM
snrusnak's Avatar
Rep:1385
How do you know when your TCC is locking and unlocking?
Sean
