Old 02-20-2012, 09:22 PM
bigred0603's Avatar
bigred0603 bigred0603 is offline
Vehicle: 2005 Dodge Ram 1500
Color: BLUE
Rep:38
bigred0603 is on a distinguished road
Default Balancing???
can spacers cause the tires to seem off balance or is it just crappy balancing by the mechanic. I have had the spacers for a while and its starting to get on my nerves the tires seem to need balanced but they just were the cab and wheel shakes alot. Please let me know what you guys think i should do.
Old 02-20-2012, 10:08 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
If they are cheap generic non-hubcentic spacers then its most likely the spacers causing the vibrations..
Remove them and hop on the freeway to verify.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 02-20-2012, 11:13 PM
bigred0603's Avatar
Color: BLUE
Rep:38
I can't remove them is the issue they are the kind that lets u use a different pattern for ur rims hOw do u tell if it's hub centric I'm new to this
Old 02-21-2012, 12:30 AM
Rep:2640
Hub Centric has to do with the Centerbore
Centerbore, The centerbore of a wheel is the size of the hole in the back of the wheel that centers it over the mounting hub of the car. Some factory wheels have a centerbore that matches exactly with the hub to reduce vibration by keeping the wheel centered. Wheels with the correct centerbore to the car they will be mounted on are known as hubcentric. Hubcentric wheels take the stress off the lug nuts, reducing the job of the lug nuts to center the wheel to the car. Wheels that are not hubcentric are known as lugcentric, as the job of centering is done by the lug nuts assuming they are properly torqued down.
Old 02-21-2012, 08:42 PM
bigred0603's Avatar
Color: BLUE
Rep:38
Ok so not sure if it's hub or lug centric witheither way how do I make sure there balanced
Old 02-22-2012, 12:06 AM
bigred0603's Avatar
Color: BLUE
Rep:38
What about hub centric rings
