Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-21-2012, 02:42 PM
Jamie71 Jamie71 is offline
Vehicle: 2001 Dodge Ram 1500
Color: Grey
Jamie71 is on a distinguished road
Default Code 442???
Hey there, i posted awhile back about not having any heat and defroster not working along with a odor in the cab. Well i am getting a code 442 and a code 420. What is the code 442, i saw in the ram manual it is the evaporative emissions control unti and says something about a leak, if so where should i look and what to look for. Thanks and any help would be great
Jamie
Old 02-21-2012, 02:55 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2849
P0442 Evaporative Emission Control System Leak Detected (small leak)
Take off your gas cap, check the gasket for problems. Look at the neck of the filler, check it for dirt. Clean it all off, put the cap on and turn it until it clicks 3 times. Most of the time that's all that is needed. If the gasket was torn or looked bad, stop at the nearest parts place and get a new one (usually under $5) and replace it.
I had to buy a new gas cap, i spent a few extra $$ & got a locking cap
P0420
Normally this code is generated by a faulty converter. You do need to verify that there are no exhaust leaks prior to the post cat o2 sensor. I would also verify that the sensor wiring is all intact and not rubbing any metal items. There is always a chance that the o2 sensor could be giving a faulty reading, but in most cases this will also set an o2 sensor trouble code. You may want to visually inspect the catalytic converter for any heat marks, dents, and even go as far as tapping on the converter with a hammer. If there are any rattling going on, it is likely the converter failure though.
Old 02-21-2012, 03:12 PM
Color: Grey
So the code 442 has nothing to do with the heater core or no heat and defroster, just asking.
Old 02-21-2012, 03:29 PM
Rep:2849
Jamie, i suggest that you go to youtube
there are a load of videos having to do with Dodge light truck heaters
3 vids are made by Heatertreater
they are trouble shooting videos
Old 02-22-2012, 10:49 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Jamie...did...you...check...the...thermal...relay? ?? I'm pretty sure I posted in your original thread.
Old 02-26-2012, 05:32 PM
Color: Grey
Hey Warlock, no I didnt check the thermal relay, wheer is that located and what is the pic of? Still trying to figure out where the smell and no heat/defrost is
Old 02-26-2012, 09:29 PM
Vehicle: 95
Rep:1776
Inside the cab, passenger's side. Passenger's left toe should be pointing at it. Check the plug and pull the 2-7mm screws that hold it in and wiggle it out. If it's bad it can cause an odor.
