Bakflip-Shim or not to shim? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-21-2012, 05:18 PM
Racklover's Avatar
Racklover Racklover is offline
Vehicle: 2012 Dodge Ram
Trim Level: Laramie 4X4
Color: Sagebrush Pearl
Racklover is on a distinguished road
Default Bakflip-Shim or not to shim?
I just got my Bakflip F1 for my 2012 shortbed. I installed it without the shims as they were not in the box. Everything went together smooth and it looks even without any tilt. I called Bakflip and they promptly sent out the shims.
Are the shims necessary? The instructions call for them up to the 2011's but this could be that the instructions were printed prior to 2012. What purpose do the shims serve? Is it added security for installation or to facilitate in the water drainage?
When the panels are folded all the way forward against the cab is it suppose to rest against the window? I put the adhesive on to cushion it when it contacts the cab/rear window. The panel closest to the cab (narrow piece) has two rubber adhesive pieces that are about 2" long that appear to cushion the folded panels. These strips are on the outside of each bolt that goes through the panel. In looking at pics of other Bakflips, I don't see these strips. Is this something new? I looked over the instructions several times and there is no mention of either aforementioned adhesive cushioning strips.
Overall, it is a nice cover and I am very happy with it.
Next mod is nerf bars
Old 02-21-2012, 06:22 PM
gshelton777 gshelton777 is offline
Vehicle: 2011 Ram 1500 Sport 4x4
gshelton777 is on a distinguished road
I installed the G2 without shims. The purpose of the shims are to keep the track parallel with the edge of the bed frame ( the lip tha tthe clamps attach to) If yours are parallel, your are ok.
Regards, Glenn
Old 02-21-2012, 06:23 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Did not use them on mine either test fit it see what you think. Also think they are for trucks without the plastic on the bed
Old 02-21-2012, 10:17 PM
Racklover's Avatar
Thanks for the replies. Gave the truck a wash and found a teenie bit of water in the bed. I had a whole lot more in the bed of my Avalanche after a wash. The amount with the F1 was insignificant and barely worth mentioning.
Old 02-29-2012, 09:32 PM
RedRiverRam's Avatar
RedRiverRam RedRiverRam is offline
Vehicle: 2011 Ram
Rep:41
RedRiverRam is on a distinguished road
I had a bak flip on my F150 and while it called for shims, I installed without and never had an issue in over 18 months of service. And you're correct, those rubber baby buggy bumpers are to cushion the BF when it folds up completely and rests against your back window. If I recall they should end up on the underside of the last panel so that when folded completely they rest against the rear window. BF is a great product, enjoy!
My OTHER rides are hot air balloons - Coyote Moon and Coyote Rising - aka Dos Coyotes!
