tonneaucovered.com
Old 01-11-2012, 12:43 AM
Jriv815 Jriv815 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Gold
Jriv815 is on a distinguished road
Default Wheel Bearing replacement
Hey guys, my ram was making kind of a wierd noise the other day, so i figured i would check it out..ya know...just to be safe. Come to find out that my front drivers side wheel bearing is close to falling apart. And i was just wondering if they are difficult to swap out or not.
Old 01-11-2012, 06:51 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Nope they are pretty easy and straight forward to swap out. I did one not too long ago on a friends Ram. Basic hand tools is all that you need
Old 01-17-2012, 06:28 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
basic hand ttools and an impact with 31mm socket amongst a few others.... just did mine today
Old 01-19-2012, 11:37 PM
HemiLonestar's Avatar
Rep:280
BFH helps as well...
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red" (Mods list in profile)
2006 Charger R/T "Little Red"
Old 01-27-2012, 07:59 PM
dakotaracer47's Avatar
dakotaracer47 dakotaracer47 is offline
Vehicle: 2007 Dodge Ram 1500
dakotaracer47 is on a distinguished road
Just changed my driver side last night, thought it was the issue, nope!
The truck started making a squeaking sound over bumps about 3-4 months ago, about 1 month ago the squeaking sound accelerated with my speed until it was a constant sound then went away. Implying that it would be a bearing of some sort, well Monday the truck started making a sound from the left front only 60-65 and over got it up to 90, LOUD. Anyway, last nigh replaced the wheel bearing, and that aint it, happened on the way home. Actually ordered the LF axel also but wouldn't u know it comes in mis-packaged. So now I have to wait till next Thursday for shop night! FML
Old 01-29-2012, 07:29 PM
leon leon is offline
Color: Arrival Blue
leon is on a distinguished road
Like someone said, basic hand tools.
For a 2007 Ram 1500 Crew Cab w 4WAL brakes, I found a USA-made replacement hub at NAPA. $205 includes new ABS Sensor.
Offshore built are available substantially cheaper.
-Remove tire/wheel
-Remove caliper with 10mm socket, 17 mm backup wrench
-Remove brake pads
-Remove caliper bracket with 22mm socket and breaker bar
-Remove disc rotor
-Disconnect ABS sensor wire.
-Remove hub unit with 18mm socket and breaker bar
-Install new hub, torque to 120 ft-lbs.
-Re-connect ABS Sensor wire
-Re-install disc rotor
-Re-install caliper bracket, torque to 130 ft-lbs
-Re-install brake pads
-Re-install caliper, torque to 24 ft-lbs
-Re-install tire/wheel
Not only did this fix the disc rotor grinding on the caliper, the cruise control works again too.
regards,
Leon
Old 01-29-2012, 08:03 PM
Rep:251
-Remove tire/wheel
-Remove brake pads
-Remove disc rotor
regards,
Leon
dont really need to remove the brake pads.... I think you need a 31mm socket for the nut on the axel end as well.. brake cailper brakcte doesnt need to come off either, just the caliper itself and hang it off of something with some mechanics wire or soemthing to that extent
Old 02-19-2012, 01:03 PM
Nutsandboldts05 Nutsandboldts05 is offline
Vehicle: 2014 Dodge Ram
Nutsandboldts05 is on a distinguished road
Looms like ill be doing this fix tomorrow in the 30 degree weather, ugh... my bearing started making noise today. I knew it was coming though. But I'm glad to know that Napa has an American made product.
Old 02-19-2012, 02:01 PM
Rep:280
I went with Timken's, they have been making bearings I think since bearings have existed.
"Big Red"
Old 02-20-2012, 10:26 AM
I usually buy Timken as well. I havent had any major issues with them yet.
