Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Warranty Issues
Dodge Ram Warranty Issues Discuss your Dodge Ram Warranty in this forum.
MOPAR DECALS
Old 02-22-2012, 02:56 PM
Roman Chariot's Avatar
Roman Chariot Roman Chariot is offline
Vehicle: 11 Ram 1500 4x4 Hemi
Trim Level: Bighorn
Color: Fire Red
Rep:13
Roman Chariot is on a distinguished road
Default Will a Dash Rattle Covered by warranty
I have a rattle in my dash that I first noticed around 6,000 miles. Now at 12,000 it has gotten progressively worse and it's driving me nuts.
I'm going in for routine maintenance this week and figured it wouldn't hurt to ask the service advisor to look at it.
Has anyone else had any luck with these types of things?
Magnaflow and YPipe, plus an S&B Intake
Old 02-22-2012, 03:01 PM
Rep:2875
It seems like i remember several members having a dash rattle
I think it was in the 2010s
Someone will certainly read your post & tell you what happened
Old 02-23-2012, 08:55 PM
jerry donihoo's Avatar
jerry donihoo jerry donihoo is offline
Vehicle: 2014 Ram Express reg cab 4x4
jerry donihoo is on a distinguished road
Im just hoping the dashes dont crack like the older models,I can always turn my radio up lol
Old 02-23-2012, 09:11 PM
Triton189 Triton189 is offline
Vehicle: 2012 Dodge Ram 1500
Triton189 is on a distinguished road
I have a 2012 and I have had the dash rattle since day one. Can't seem to pinpoint what is causing it. I believe it may be a wiring harness behind the radio bezel tapping....? If I put my hand on the dash towards the pass side it goes away.
Old 02-24-2012, 09:25 PM
2002z28 2002z28 is offline
Vehicle: 2011 dodge ram
Trim Level: Slt
2002z28 is on a distinguished road
YEs it will be covered. Had mine in on e already. Still have a rattle. It's going back in
Old 05-24-2012, 02:43 PM
mrcivic's Avatar
mrcivic mrcivic is offline
Vehicle: 2014 Dodge Ram Crew Laramie
Color: Maximum Steel
mrcivic is on a distinguished road
my dealership made a feeble attempt of fixing it, same thing behind the radio under the top, only seems bad when it is warm. I am wondering if Chrysler will give me a rental vehicle for this as I have to drive almost an hour to take my truck there and then they want me to be ready for a day or two. I am not impressed that they did not even take the dash apart last time just pulled off a bezel and stuffed some foam behind it and put a big scuff in the bezel. They told me that there was no rental option but I might call Chrysler Canada and see.
Old 08-14-2012, 10:45 AM
malavalley malavalley is offline
Vehicle: 2011 Ram 1500 Big Horn Quad
malavalley is on a distinguished road
My dash rattled in my 2011. You could alleviate the rattle by ever so slightly pressing down on the dashboard itself above the radio. After 3 failed attempts by the dealer to repair it I pulled the radio and bezel out to investigate. What I found was the union to the defrost duct was too tight and would rattle with movement(there is a foam seal for reference that hides the joint). Since they glued the duct to the dash board, any time the dash board vibrates it cause the two ends of the duct to rattle together and resonate through the dash. I ended up removing the foam seal and carefully trimmed the ducts with a razor. I resealed them with some gorilla duct tape...no more rattles. I also did my fathers 2009 sport so probably problem over series of years. Hope that helps.
Old 08-16-2012, 08:43 AM
LUBINATOR's Avatar
LUBINATOR LUBINATOR is offline
Vehicle: 2009 Ram 1500 SLT Quad Cab
Color: Inferno Red
Rep:12
LUBINATOR is on a distinguished road
Default Rattle
I had a rattle on passenger side fairly close to where windshield, pillar and dash all meet.
I had the dealer remove the dash under warranty and they did find two sections of metal to plastic that were "clicking" together. When they had the dash apart I asked them to "pack" any suspect areas, including cables/wiring, with padding and I have no more rattle since.
I was going to take dash off myself, but watched them do it instead.
Make them do it while still under warranty.
Richie
RAM 1500 SLT QC 2009 INFERNO RED, ARE Lift Lid ,Spray on Bed Liner, K&N Drop In, Pioneer DEH P8400UB, Alpine Amp, Mopar Kicker sets in all doors and dash, 2 Polk 10" Subs, Polk AMP, SteelCraft Nerf Bars, Mopar Fog Lights, CalTrend Seat Covers, WeatherTech Front Mats, Putco SS Fender Liners, SuperBumper SS Hitch Step/Impact Absorber, Onki Aegis SS Center Guard, PIAA 2100 driving lights
Old 03-07-2014, 12:56 AM
Airdog's Avatar
Airdog Airdog is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4x4
Color: Detonator Yellow
Rep:37
Airdog is on a distinguished road
My 2009 Sport had this problem. The T shaped defrost duct behind the radio was too tight and would rattle with movement (there is a foam seal on it that hides the joint). Since the duct is glued to the dash board, any time the dash board vibrates it cause the two ends of the duct to rattle together and resonate through the dash. I ended up removing the foam seal and taped them with some gorilla duct tape...no more rattles.
Here's a video of exactly what I heard... very pronounced at the :40 sec mark.
~Airdog .
Old 03-12-2014, 01:21 PM
Buellrider's Avatar
Buellrider Buellrider is offline
Vehicle: 2012 ram 1500 R/T
Trim Level: R/t
Color: Wht
Rep:145
Buellrider will become famous soon enoughBuellrider will become famous soon enough
I had a dash rattle fixed on my 12 R/T under warranty...
2012 R/T
