Old 06-16-2012, 11:12 AM
Vehicle: N/A
Rep:1045
hell yea man! really enjoyed this one!
Old 06-16-2012, 01:17 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The little device in question near the battery with the small vacuum lines on it is the EVAP canister purge solenoid.
If you run into a problem with the belt slipping on the crankshaft, you may be able to reroute the belt so the drivers side off the crack goes to the water pump, then to the PS pump then up to the A/C compressor. This would reduce the contact at the A/C compressor and PS pump a bit, but would give a real good wrap on the CS and maintain the good contact on the water pump. Not sure if you have full clearance for the belt in that route without seeing the path from the PS pump to the A/C comp.
I have to say that you did awesome time wise considering the modifications required to get everything to fit. Projects like this require a lot of resourcefulness to over come the obstacles that present themselves along the way.
I hope to be able to see this beast in person this summer.
brad
Interested in one of my mods?
Old 06-16-2012, 01:20 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Nice work and Rep for taking the time to document so well for us!
Old 06-16-2012, 02:50 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
Well done and being able to provide your build and journey in detail is great.
Old 06-16-2012, 03:40 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Nice work Kurtis! We have to meet up this summer so I can see this newly modded beast again!
Big Red my old 2011 Sport
Old 06-16-2012, 05:03 PM
moparornocar72's Avatar
Rep:630
Great work man! Makes me wish I would have kept my 6.1L intake for later on down the road. Oh well! I'm guessing your getting a tune for your new cam?
14.268 @ 95 MPH Full Trim
Old 06-16-2012, 06:28 PM
I push the skinny pedal
Rep:3277
I do have a tune already built by Johan and we will be fine tuning it over the next month, then I'll get a nitrous tune and the fun really begins.
Kurtis
Old 06-16-2012, 10:41 PM
DaKing DaKing is offline
DaKing is on a distinguished road
great write up, an pictures.
I'm installing a 6.1 based 426 in my ram, and your info has answered many of my questions. I'm even going to use the same NOS plate.
If you have any more picks, please post..
Thanks
Old 06-16-2012, 11:14 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
You RAM is coming along great man! I really likey...keep up the good work so "the masses" will be pleased LOL
MATT
Old 06-17-2012, 12:26 AM
Rep:3277
If you are dropping a 6.1 based 426 then I'd try and get all the 6.1L accessories as well so you don't need to use the bracket. But if you do go with the same accessories and the nitrous plate you will need to make the same modifications to the timing cover and the bracket.
Kurtis
