Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 03-10-2012, 07:24 PM
ecoloqua ecoloqua is offline
Vehicle: 2007 dodge ram 2500
Color: grey
ecoloqua is on a distinguished road
Thanks for the responses guys. Someone else also said to check the bushings where the bed mounts to the body. Not sure if thats what you mean by cab mounts I had the dealer do that and they checked out ok. As far as the cross members, frame rails, spring mounts I have no idea how to check those things and I would have to tell the dealer to check them if thay have not done so already. I will call my tech and ask him if he has checked them yet.
I really want to keep this truck. It' s the perfect truck and everything I want save for the handling but its getting exhausting trying to figure this out.
Old 03-12-2012, 06:29 PM
Rook's Avatar
Rook Rook is offline
Vehicle: 2003 Dodge Ram 2500
Trim Level: Custom Truggy
Rep:39
Rook is on a distinguished road
After driving a Jeep for years with a disconnected front anti-sway bar, I'd have to say that your problem is likely related to the front anti-sway bar. Your symptoms sound exactly like what many Jeep off-roaders just get used to after being to lazy to reconnect the disconnects.
I have not seen in the previous posts were this is mentioned. Be sure to check that the bar itself is not loose within the bushings. I always replace the the stock rubber bushings with poly. Also, make sure there is NO play in the joints were the links connect to the axle. The joints are a ball style and often pull out under heavy stress.
Topless 2003 Dodge Ram 2500 - Hemi - Truggy - 2.5 Ton Steering Rockwells
Old 03-12-2012, 06:53 PM
IN2H2O's Avatar
IN2H2O IN2H2O is offline
Vehicle: 2003 Dodge Ram 1500
Rep:73
IN2H2O will become famous soon enough
I drove my current truck for over 100K miles with no issues and then I went thru a patch where the steering was real sloppy,the understeer was dangerous and I could not keep the front end aligned. I wore out a cheap set of tires in under 25K miles. I ended up putting a set of 20" Michelin LTX's on it and it smartened right up. Bilsteins are next.
Having said that, I don't consider BFG's to be cheap by any means.
