Old 02-23-2012, 02:12 PM
Morlow Morlow is offline
Vehicle: 2002 Dodge Ram
Rep:20
Morlow is on a distinguished road
Default Help me identify the brake booster vacuum (for Seafoam)
So I've been reading about the magic of Seafoam so I figure I will give it a shot. My truck has 112k miles and I am about to embark on a 3.3k mile trip. I'm just not sure which hose is the vacuum hose. I looked on Youtube and searched on here and no one specifically shows which hose.
Red or blue?
Old 02-23-2012, 04:42 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Blue is the one you are after. Just pump up your brakes until they are hard, unplug the hose and pour your sea foam in there. The reason for pumping up your brakes (when truck is off) is to use up the vacuum reserve in the booster to make the hose easier to pull off the check valve.
Sure it'll suck, but it'll make you a man
Old 02-23-2012, 04:58 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Blue FTW!
You can also run the seafoam through any other vacuum lines that are attached to the intake manifold/TB.
Sean
Old 02-23-2012, 05:16 PM
Rep:2616
Old 02-24-2012, 07:02 PM
Rep:20
I seafoam'd today. I just put it in the brake booster vacuum and the gas tank, since I just changed my oil a week ago. I got lots of smoke! I will keep you updated if I notice any difference with performance or mileage.
Old 02-24-2012, 11:07 PM
Kong's Avatar
Kong Kong is offline
Vehicle: 2012 Toyota Tundra
Trim Level: SR5
Color: Metalic Grey
Kong is on a distinguished road
I thought you were supposed to do it before you change the oil. Run it about 50 miles and change it out. Or is that only when you put it in the oil?
Old 02-25-2012, 01:39 AM
Rep:20
I think that's just if you put it in the oil.
Old 02-25-2012, 01:53 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I never got a smoke show out of either of my trucks?
Mike
Old 02-25-2012, 04:49 AM
Rep:2616
The reason that they don't put it in the oil ( crankcase ), is because todays motor oil has all the detergent & additives to keep your block clean in the oil passages & every where oil belongs within the engine block
If you were to buy a gunked up vehicle, that was not serviced properly, then possibly adding it to the crankcase might break gunk loose & you would do it not too long before a oil & filter change.
Old 02-25-2012, 01:32 PM
ramfanatic01 ramfanatic01 is offline
Vehicle: 2004 dodge ram
ramfanatic01 is on a distinguished road
my truck has 138000 miles on it seafoamed and got very little smoke is this good or bad
