Help me identify the brake booster vacuum (for Seafoam) - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-25-2012, 02:52 PM
Morlow Morlow is offline
Vehicle: 2002 Dodge Ram
Rep:20
Morlow is on a distinguished road
I would assume it is good, meaning you don't have much gunk build up in your engine, but I could be wrong. On a side note, is there such a thing as too much Seafoaming? I was thinking that since I don't know my truck's past history I would Seafoam every oil change for about 4 oil changes then go to every other oil change.
Old 02-25-2012, 08:31 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I don't think it can do any harm, but I certainly wouldn't waste the money. Do it once every 50k miles or so and that's more than enough. If there wasn't much smoke it means the engine is clean.
Sean
Old 02-26-2012, 11:23 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
does seafoam not also come in a pressurized can with a hose that can be sprayed right into the intake before the throttle body?
Delco used to also make a product called Cleens...it also had a pressurized can with a hose that you just sprayed into the throttle body while the engine was running..shut er down let her soak in and then run (just like the seafoam).
Old 03-01-2012, 11:00 AM
BWhelan BWhelan is offline
Vehicle: 2007 Ram SLT Regular Cab
Color: Grey
BWhelan is on a distinguished road
I honestly need to read up more on the Seafoam, because it sounds like it would be dangerous on the engine to me. - though I'm sure it's not because it's been around forever.
How exactly does it work? (I'm going to google is as well)
Old 03-29-2012, 09:35 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
I seafoamed my old car before, and never had issue with the engine or anything after that. If no smoke comes out your engine is clean so that is good! How I did it with my old car was I would pour the seafoam in a solo cup, take line off and just keep it just touching the port so I could start engine, then put hose in solo cup for it to suck it up and let the engine run till it dies. Then I have it sit for a little then connect hose and start it up and go for a drive.
Is that a wrong way to do it? Also is it better to do after oil change or before? I did before on my car.
Old 03-30-2012, 01:24 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
That sounds like the way to do it to me. I fed my 2006 4.7 about half a bottle through the vac line and it didn't hurt it. I couldn't tell any positive difference either but I like to think it was cleaner on the inside, lol. I don't think it matters about the oil change as long as you are only running it through the induction system or adding it to the gas tank and not putting it in your engine oil. Some have done it and it may be fine but I personally don't recommend adding Seafoam or anything else to your oil.
