Old 02-23-2012, 05:09 PM
SNAKEBIT-TX21 SNAKEBIT-TX21 is offline
Vehicle: 2011 Ram 1500 4x4 Laramie
SNAKEBIT-TX21 is on a distinguished road
Default Depressed
got 7500 mi. on the new 1500 4x4 Laramie and never been so disappointed in a new vehicle in all my life!!!!
won't spin a tire,won't downshift around a corner when you slow to 20 mph,throttle lag/response is crazy!!!
we have a 11 year old Toyota 4 cyl that will spin the tires harder!!!!
acts like all the shocks are bad at speeds over 50 on the freeway.
stereo display will not auto dim at nite. the list goes on!!!!
getting barely 11mpg around town and about the same on the freeway pulling a Bassboat.
may go back to driving the 98 Suburban 2500 4x4 with the 454!!!
Old 02-23-2012, 05:30 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
You have to turn the traction control button off to spin the tires. I average 12-14 mpg with or without my bass boat attached. Don't drive much at night so I have never thought aboute auto-dim but thus far it has not bothered me. As for the other issues, I can't say as I have not noticed them in my Laramie.
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 02-23-2012, 05:40 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
What gear ratio do you have on your Laramie?
Make sure you turn off the MDS by manually shifting to 5 using the +/- on the shiter. Turning off the MDS will make the truck feel completely different.
I have plenty of power to spin both tires even with 3.55 gears and limited slip and with the traction control off it is even better.
Old 02-23-2012, 06:05 PM
Rep:2642
MPG gets better the closer you get to 5,000 miles
I don't use high gear in town/city, just on the highway
If you want to dim the radio, i believe that the headlight rheostat controls the instrument panel & radio, as well as the ash tray light in the overhead console
If it does not control the radios light, go into the radios MENU, you can set the brightness, i forget the settings
I have the full floor console & i paddle shift manually, it is not perfect
The new cars have AutoStick, i hope the Rams get it soon
Chrysler's 45RFE, 545RFE, & 65RFE are the same transmission, just upgraded software
The 45RFE has been around since 1999, time for a major change
Old 02-23-2012, 09:11 PM
sylster's Avatar
sylster sylster is offline
Vehicle: 2011 Dodge Ram sport
Color: hunter green
Rep:19
sylster is on a distinguished road
Send a message via MSN to sylster
Just throwing in my 2 cents....not trying to attack anyone....but coming here and bashing the trucks....probably gonna get some backlash from that kinda comments
won't spin a tire, Mine does...no problem
won't downshift around a corner when you slow to 20 mph,throttle lag/response is crazy!!! a bit annoying but putting it in "5" manually kinda fixes that
is it standard or automatic?
humm...can't comment mine ride just fine
the auto dim works perfect on mine....I'd have that check.
Well....if you're steeping on it all the time to break the tires free and have a lead foot....yeah...they're hard on gas.....I get 15MPG pulling my travel trailer with my 3.92's at 65MPH.....Just saying the right foot has a lot to do with it
How's the gas mileage on that?
Just saying....I can't complain about mine and the issues you're having...some I'd get checked and some I'd take a look at how I'm driving....I have a lead foot and IT SUCKS GAS BIG TIME.....if I wanted good fuel economy I would if looked at a Civic...not a 390HP truck.
S.
Old 02-23-2012, 11:36 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
sylster, tell me more about the auto dim on the radio.... tks steve
Old 02-23-2012, 11:43 PM
sylster's Avatar
Color: hunter green
Rep:19
Not much to say....lights come on....radio dims....lights go off...gets brighter....
I think it's a feature taht can be turned on and off....let me check and I'll chime in later
S.
Old 02-24-2012, 12:01 AM
LeKy411's Avatar
LeKy411 LeKy411 is offline
Color: Blue
Rep:100
LeKy411 will become famous soon enoughLeKy411 will become famous soon enough
Auto dim is in settings in your radio somewhere under display. Once you have that set it should auto dim, if not here is why...... Every car has a dash light intensity dial. The Rams dial is under the headlight switch. It has two notches. Turning it fully left will turn on all cabin lights this is one of the notches. Going one notch to the right will give you full dashboard brightness. If you leave it set on that unfortunetly the radio will not auto dim. Turn the dial to the right past that notch, you may notice a slight dim in the dash and your auto dim on the radio will work.
I had the same issue and it took me a week to figure it out. Hope this helps
Old 02-24-2012, 12:06 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Wow, I have had none of those problems. I can repeat everything that "sylster" stated and more. I can certainly crack the tires loose with no problem, just have to set things up properly. All the electronics on board try hard to prevent you from doing that, just have to turn them off.
Old 02-24-2012, 12:31 AM
sylster's Avatar
Color: hunter green
Rep:19
Here's a picture of the page in the menu setting on the radio.
Hope it helps.
S
