Old 02-23-2012, 09:51 PM
ramrick14 ramrick14 is offline
Vehicle: dodge ram 2010
Trim Level: sport crew cab
ramrick14 is on a distinguished road
Default Integrated Brake controler question
When roads are icy and the ABS system goes on my trailer brake are released...
The brake controler was installed after the purchase of the truck but the product is the OEM one.
Any thought?
Thanks
Rick
Old 02-24-2012, 11:07 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
To me, that sounds correct. I would guess the pcm recognizes when the ABS pump kicks in and then releases the trailer brakes to avoid having the trailer brakes lock, sliding/pushing the truck out of control...
Sean
Old 02-25-2012, 05:44 PM
Default brake controler
Thank you for the info but, if a got a 4000 pounds trailer in the back and the ABS on the truck goes on and released the electric brake ALSO.
I think the trailer is going to push even more the truck out of controls and into the ditch.
What I am tring to figure out is,anybody knows why or how to get the right signal from computor that there is a trailer hooked up in the back and PLEASE apply brake so I will not injured or kill anyones
thank you guys.
Old 02-25-2012, 08:03 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
Have you had the dealer flash your computer to recognize the brake controller?
Old 02-25-2012, 08:25 PM
snrusnak's Avatar
Rep:1385
Locked trailer wheels sliding on ice is much worse than free spinning wheels being slowed by the truck w/ABS. I don't exactly know that's how the system is designed, but I would almost guarantee it is that way. It doesn't sound like anything is wrong.
If the trailer brakes lock and the trailer slides while the truck is pumping the brakes with the ABS pump the truck will be slowing faster than the trailer, and what will happen is the trailer will kick around beside you. You don't want the trailer brakes locked...
Sean
Old 02-25-2012, 11:41 PM
GearHd6's Avatar
Color: Mineral Gray
I'm with Ramrick, it doesn't seem safe to kill the trailer brakes when the ABS kicks on. These trucks are supposedly able to haul 10,000 lbs if "correctly" equipped. Imagine all that weight being thrown onto the truck brakes in a panic situation....., not good.
Old 02-26-2012, 09:46 AM
snrusnak's Avatar
Rep:1385
Well I'm not trying to be a jerk about this, but just imagine that weight sliding up beside you... it just doesn't make sense to me to allow the trailer to lock up (unless maybe the ABS would disengage/engage the trailer brakes at the same times the truck brakes were pumping).
With the truck using ABS and slowing down and the trailer being locked and sliding (not slowing down as fast as the truck) the hitch/ball is a pivot point and the trailer is going to pivot sideways since it has no resistance from the tires to the road keeping it straight...
I agree it's a bad thing to have all the weight of the trailer being free rolling pushing your truck, but it's worse to have it locked up. That's why you're supposed to drive slower and safer so this doesn't happen.
Sean
Old 02-26-2012, 10:08 AM
GearHd6's Avatar
Color: Mineral Gray
I didn't say you were being a jerk. I'm a class A truck driver so I know the deal with trailer braking. I think you're much better off leaving the braking up to the driver in a panic situation. Think of this, push 10,000 lbs of trailer with NO brakes against a truck with ABS, the more the truck is skidding the more the ABS is going to keep pulsing and the further the stopping distance will be. Plus, totally killing the trailer brakes is going to cause a HUGE surge against the truck in an already hazardous situation. Think of it as a HUGE load shift in a 53' tractor trailer, that usually causes a roll over. Either way, it is probably going to be a bad situation.
Old 02-26-2012, 10:10 AM
GearHd6's Avatar
Color: Mineral Gray
In the end, if it were me and I couldn't cure the trailer brakes from being disabled I would pull that controller out and sell it on Ebay and buy something like a Prodigy.
Old 02-26-2012, 10:11 AM
snrusnak's Avatar
Rep:1385
Well my thought is that they designed the oem brake controller that way for a reason...?
Sean
