Old 03-01-2012, 08:59 PM
Ironsides Ironsides is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Trim Level: SLT Big Horn
Rep:44
Ironsides is on a distinguished road
How do you know the trailer brakes were releasing?
Old 03-01-2012, 09:09 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
I would assume he could feel all the weight of the trailer pushing against the truck at the moment his trucks ABS kicked in. Just a guess....
It sounds like he hooked his trailer up again today on snow/ice roads and tested it out.
Old 03-02-2012, 02:07 AM
Dustinmc15 Dustinmc15 is offline
Rep:73
Dustinmc15 will become famous soon enough
So does that mean those who install the factory brake controller but cannot have it recognized by the EVIC will have this problem (no trailer brakes when ABS is activated)?
Old 03-03-2012, 01:46 AM
ramrick14 ramrick14 is offline
Vehicle: dodge ram 2010
Trim Level: sport crew cab
ramrick14 is on a distinguished road
Yes guys,
If you purchase and installed it yourself everything works fine exept when the ABS kicks in.
To know if your option [ ITBC] as been activated , if you can, try in a parking lot when raining or snow apply brake has hard has you can so the ABS will kick in and watch the brake controler digital number, it will go from a {let say 5.0} to 0.
Also if the option is on ,you will see it on the EVIC {trailer brake},if not then the option is not activated.
I had the brake controler for the last 2 year, and thought evrything was fine {ecxept when the ABS was on} found it weird,but did not complained to much since the dealer said it was maid like that.
Thank`s guys
