Old 02-24-2012, 12:40 PM
BruteEngine BruteEngine is offline
Vehicle: 2009 Dodge Ram
Color: Stone White
Rep:25
BruteEngine is on a distinguished road
Default 4.7L Spark plug torque spec?
Hi guys, It's been a while since I have been on here. I am getting ready to change the plugs in my '09 Ram 1500 with a 4.7L.
I was wondering what are the torque specs are for the spark plugs?
Old 02-24-2012, 01:05 PM
ArmyofOne's Avatar
US Army Retired
Rep:1189
IIRC its 11ft-lbs. I would have to check. Let me get back to ya. I JUST changed mine like a month ago too.
Make sure you get the tool from autozone to remove the boots, or you will tear them. at $42 a piece, it could be worse, but when you start tearing 3, 4 or 5, it can get spendy.
FWIW, generally, with plugs, I just check the gap, and get them to german torque specs...Gutenteicht (Goodandtight)
Diesel Technician-PACCAR Inc.
Old 02-24-2012, 09:43 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The Chrysler Tech Authority manual says 20 ft/lb. Tighter than I expected.
brad
Interested in one of my mods?
Old 02-25-2012, 11:17 PM
Color: Stone White
Rep:25
Thanks for the help! I did them today and it worked out better than I thought it would I just took my time and did them one at a time (only the top eight).
I torqued them down to 120 in/lbs (10 ft/lbs). I hope that is enough!
Old 02-26-2012, 04:04 AM
ArmyofOne's Avatar
US Army Retired
Rep:1189
You will be fine. Its rare that a plug comes loose in a head. The difference between 10 and 20 ft. lbs is not substantial.
Old 02-27-2012, 03:10 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I cant see even bothering to hit plugs with a tq wrench. Snug em down and 1/8th turn should be more than enough force keepin em in
2011 Big Horn 4x4 -SnowWhite-
