Need some help and advice - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-25-2012, 02:45 PM
dhellman dhellman is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman
Color: blue
dhellman is on a distinguished road
Default Need some help and advice
Does anyone know where I can find Bilstein 5100's front and rear for a good price? To level out the front end of a 2011 1500 4X4 outdoorsman. Or is it better to go with a lift kit?
Old 02-26-2012, 01:18 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I would definitely go with the Bilsteins rather than a spacer kit. I just installed all four on my 2006 quad cab and I love them. This should help make up your mind.
http://www.bilsteinus.com/fileadmin/...WebArticle.pdf
As for the best place to get them....it seems like they are pretty evenly priced everywhere I looked. Summit Racing or shockwarehouse.com seem to be about the lowest I've seen.
Old 02-26-2012, 01:42 PM
seltzer seltzer is offline
Vehicle: 2009 Dodge QC 4x4
Color: Pearl Black
seltzer is on a distinguished road
Great link on the shocks! Some seriously good information there.
It doesn't say whether an alignment is needed afterwards though, but I'm guessing yes?
If You Can't Beat Them...Arrange To Have Them Beaten.......George Carlin
Old 02-26-2012, 03:01 PM
Color: blue
Thank you for the info. What is your clearance now? But do you know if it will cause the death wobble? Due to being an outdoorsman package?
Old 02-26-2012, 09:41 PM
Rep:367
Yes, an alignment is required after installation.
I just reread your original post and I guess I should have clarified...by lift kit did you mean an actual all the way around suspension lift kit or were you talking about a spacer-type leveling kit? My response was geared towards choosing between the Bilsteins and a spacer leveling kit. Obviously I recommened the Bilsteins hands down. As for an actual lift kit, it really just depends on what you want to do. If you are just looking to level the front, I still recommend the Bilsteins. They are a top-quality product and will level the front safely at a fraction of the cost of an actual suspension lift kit.
As for my clearance....I assume you mean what size tire could I clear now? I knew I was going to be leaving the stock 275/60/20 on so I only set my Bilsteins at 1.4" of lift. Most people go with the full 2.1" on the third gen trucks or the full 2.8" on the fourth gen trucks. I'm happy with mine because it still has a very, very slight front rake so that it won't squat when I haul something and the stock tires don't look too small. I did measure before and after and it seems to have given me exactly the amount of lift that it said it would at that setting. I'm sure I could very easily clear 35" tires with only my 1.4" front lift.
As for the death wobble question....I don't know about the fourth gens but I know that some of the third gen trucks reportedly have a slight vibration in 4x4 from the factory as a result of the stock suspension geometry. Some have reported that this can be slightly intensified by a leveling kit. It seems to be hit and miss....some have it, some don't. I personally have never noticed it before or after the level. I also don't know if or how the front suspension on an Outdoorsman differs from a regular fourth gen Ram. I would try some googling because I bet there is info out there on this topic. Also, maybe someone with a little more info will chime in.
Old 02-27-2012, 08:10 AM
Rep:367
Well this doesn't apply to me so I don't know why it interested me so much but it did, lol. So I did some googling of my own.
It seems to be a point of contention among some but most people agree and measurements seem to show that the Outdoorsman has 0.7" of front lift from the factory over non-Outdoorsman trucks due to using a longer strut. If you were to use the Bilsteins (which I obviously recommend) you would be taking that 0.7" of front height away when you remove the stock strut. So if you installed the Bilsteins set at 2.8" of lift you would actually only gain 2.1" of lift compared to what your truck was with the stock Outdoorsman struts. I read several posts from a guy on a couple of different forums (name was second_life or something like that) that did this exact thing and stated that he only got 2.1" out of Bilsteins set at 2.8". I also read a few posts from people claiming to be running a 2" spacer-type kit (which would actually make it sit 2.7" higher than other Rams) on an Outdoorsman with no issues.
I would suggest you measure the difference between the front and rear of your truck and see how much front lift you are interested in trying to make. I measured from the ground to the lip of the fender when I did it. Also think about whether you want to try and get it as close to dead on as possible or whether you need a tad of front rake left for hauling, towing, etc. I still have roughly 1" of front rake in my truck but most of the time, depending on how I park, it looks near dead level to me.
In conclusion, I recommend the Bilsteins set at whatever height you decide you want and I think you will be happy and very seriously doubt you will have any issues. Good luck and sorry for the long posts....boy, I sure do like to talk, lol.
Old 02-27-2012, 09:47 PM
Color: blue
Starquestbd22 thank you so much for the good info. I think I will take your advice and go with the Bilstein 5100 set at 2.8 so it would leave me at 2.1 and a 1" rake for hauling. Once again I really appreciate the work that you did.
Old 02-28-2012, 12:23 AM
Rep:367
No problem. Glad to help. If you haven't already I would recommend that you google (google knows all, lol) for some photos of fourth gen trucks with the Bilsteins at various settings. You will probably find that most people set them at the max but some do go for the next to last setting. That way you can see the difference and decide what you like best.
Just something to keep in mind....if you go with the highest setting (2.8") on your truck you will be getting 2.1 inches of lift compared to what your truck was before just like you said. But you will be getting the full 2.8" of lift compared to any other stock non-Outdoorsman Ram. I don't know that there will be any rake left with the full 2.8" lift. The second to last setting may be better if you want a little rake left. It would only be 1.4" higher than your truck now but it would be 2.1" higher than a stock non-Outdoorsman. You will have to look at some photos and decide how high you want it.
Old 02-28-2012, 11:36 PM
teucopper teucopper is offline
Vehicle: 2006 Dodge Ram 1500
teucopper is on a distinguished road
I got my set on ebay. it came with all four for 300.00 The seller was topgunz customs. they shipped the shocks and rear blocks in about a week and a half.
