Old 02-25-2012, 06:50 PM
Silver Ram Silver Ram is offline
Vehicle: 2011 Dodge Ram 1500 4X4
Silver Ram is on a distinguished road
Question Billet Catch Can Question
I installed the Billet catch can just after my first oil change. It's about time for my second change and so I decided to check the contents of the can. The damn thing was nearly full to the rim... Is this normal? Also, I noticed the content was murky and had a pretty noticeable fuel odor. Is this normal as well? If it matters, I do not race the truck and normally drive like a grandpa.
Thanks for your advice in advance.
Old 02-25-2012, 07:44 PM
smusher's Avatar
smusher smusher is offline
Trim Level: st with ram express
Rep:25
smusher is on a distinguished road
Sound about like mine. It's just a product of 10.5 ta 1 compression. Dodges have always been bad about oil blow back anyway.
Old 02-26-2012, 09:54 AM
doug713's Avatar
doug713 doug713 is offline
Rep:33
doug713 is on a distinguished road
I change mine about every 1500 miles. It is usually over half full at that point..
Old 02-26-2012, 10:46 AM
Thanks fellas. I will definetly check it more often than before. I'd been noticing some extra (more than normal) black soot on my exhaust tips the last couple of days and thought to check the can. My guess is allowing the can to fill caused some of the blow to make it to the intake. Live and learn!
Thanks again.
Old 02-26-2012, 11:12 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Sounds normal, I checked mine after only two weeks and it had about an inch in it and it looked like what you described. Just remember that without the can all this would have recyled through your intake.
Old 02-26-2012, 12:15 PM
MWO Sean's Avatar
MWO Sean MWO Sean is offline
Vehicle: 2011 Ram Big Horn Crew Cab
Color: Blue
MWO Sean is on a distinguished road
Default Billet Can
Being a new truck owner and not mechanically inclined, is the installation of a catch can something I need to be concerned about?
Old 02-26-2012, 12:56 PM
johnnymopar's Avatar
johnnymopar johnnymopar is offline
Vehicle: 1998 in between truck GM 1500
johnnymopar is on a distinguished road
Hi Sean, the answer may be different for different people. How long will you keep the truck? Do you plan on keeping it for many years and 200,000 km?
Like mentioned before it keeps unburned oil/fuel mixture from being recirculated and burned in your engine. It is not necessary but does keep your plugs, intake cleaner over time. On supercharged and high performance engines it is a must. It does not hurt but definitely helps a bit, especially over time and mileage.
It does require moderate mechanical ability to install (good right ups on this forum how to) and then needs to be emptied periodically. I have one on my car and truck, both I plan to have for a long time.
Old 02-27-2012, 12:56 PM
MWO Sean's Avatar
Color: Blue
Thanks,
I'll do some more research before I make the call.
