Old 02-26-2012, 12:22 AM
mastercoy1111 mastercoy1111 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Blk
mastercoy1111 is on a distinguished road
Exclamation 02 4.7 in a 04?????
I have a 04 ram with a 4.7, i had a secondarytiming chain issue which in turn caused a vavle issue, anyway, I got a great deal on a re-man engine with less than 1o,ooo miles in a 02 ram, i put the engine in my truck and it will not start???? I was told by someone that the 02 engine is not compatible with my 04 and there was nothing I could do to make it work....Is this true? if not what do I need to do......Help me my Mopar Brothers!!!!! I did hear it run before I purchased it........
Old 02-26-2012, 02:55 AM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
ok the 04 has a 32 tooth sprocket on the crack that is only compatible with the 4 plug pcm for you to make it work you will need a 16 tooth sprocket and a 3 plug pcm. You can change out the Sprocket from the engine but doing the PCM change is easier if you got the engine already in. ? Some will agree some won't but My buddy did it and he running good
