e3 diamond fire spark plugs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-26-2012, 06:12 PM
stimleck stimleck is offline
Vehicle: 2010 Ram Crew
Trim Level: Laramie-Loaded
Rep:14
stimleck is on a distinguished road
Default e3 diamond fire spark plugs
On horsepower tv they were showing some Michigan Tech testing that was very clear about the benefits of this style of plug.
has anyone tried them in a 5.7 with mds?
Old 02-26-2012, 08:32 PM
mastertech10 mastertech10 is offline
Vehicle: 2013 RAM 1500
Rep:12
mastertech10 is on a distinguished road
dont use these e3 plugs. i have had many customers come in with idle and misfire issues as a result of these 'performance' plugs. save yourself the money and buy the oe plugs the engine was designed to run with.
Old 02-27-2012, 03:06 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I have had friends try and run them in their LS1s with the same result as ^^^
Dont be fooled, a little bit of support money goes a long way with dyno "findings" and vehicle reports on TV shows. Notive when the tornado came out of whatever it was called the "testimonials" from some of the car shows were along the lines of "Its like I added a supercharger to my car!"... think how many people bought them because of that lol
These Hemi's seem to like just stock plugs
2011 Big Horn 4x4 -SnowWhite-
Old 02-27-2012, 03:08 PM
mttviper mttviper is offline
Rep:96
mttviper will become famous soon enough
That magical device that created the vortex in your air intake and added about 50 hp and got you 15 more MPG! AND IT WAS ONLY 40$!
If anything, the price should of indicated do be an idiot. 40$ for a device to create gains no one else could? SIGN ME UP!
Old 02-29-2012, 01:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I used the E3 plugs in my s10, it idled poor and seemed sluggish. Switched back to oem plugs and idled and ran better.
Recommend using stock plugs. If you have a lot of mods you may benefit (very slightly) from going a heat range colder.
Sean
