Air leveling kit question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-26-2012, 11:15 PM
clatla's Avatar
clatla clatla is offline
Vehicle: 2014 Dodge Ram
Color: Snow White
Rep:31
clatla is on a distinguished road
Question Air leveling kit question
I am looking to install a set of airbags in the rear of my truck. It sags pretty good when hooked to trailers. My question is who has had good luck and who has had bad luck with different kits. I want to have a onboard compressor. Do you have any issues with sway if the bags are connected to each other? I found Air Lift bags for pretty reasonable. Then find a good kit with a compressor.
Thanks in advance for any advice.
Old 02-27-2012, 01:36 PM
dig dig is online now
Vehicle: 2010 1500 Dodge Ram Crew Cab
Trim Level: SLT- Big Horn
Rep:27
dig is on a distinguished road
Default Air Lift
I installed the airlift 1000 with the wireless one compressor unite. Seam to work fine, I installed the compressor under the rear seat. I used the wireless so I did not have to run a lot inside the cab, the only reason I installed the compressor inside was for the dryness and cleaner.
