Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 02-27-2012, 02:22 PM
7828875 7828875 is offline
Vehicle: 2009 Dodge Ram 1500 4x2
7828875 is on a distinguished road
Default Power inverter Won't work
I used to use my power inverter all the time to charge my Iphone, but switched to the 12v outlet because it works when the truck is turned off. I tried to use it again last week and although the light turns on indicating its on i get no power from the outlet. Anybody have any idea what might be causing this. I checked the fuse box and the fuse is fine. The manual says the inverter will protect itself when too much power is drawn but doesn't say anything about a reset button or procedure.
Anybody have any info about this?
Old 02-27-2012, 05:12 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
There's probably a fuse in the inverter's tip. See anything that unscrews?
Old 02-27-2012, 07:16 PM
The inverter is built in to the dash
Old 02-27-2012, 07:46 PM
Rep:2616
UMMMM
If i remember correctly
the inverter is mounted on the passenger seat frame, just under the cushion on a bucket seat Ram, it is right at the front of the seat
It may be located in the center of a bench type seat
look at post number 2, made by RamTech
http://www.ramforumz.com/showthread.php?t=77384
Old 02-28-2012, 12:50 AM
Rep:85
Huh. Built in. I was thinking about a plug in model.
