Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 02-27-2012, 03:36 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Talking O2 sensors- how much???
So, I confirmed I have 4 O2 sensors and my mechanic said that according to his vendors they are $102 EACH!!!! Does anyone have a line on better prices? And I cannot use the "universal " type.
Thanks again,
Mad
Old 02-27-2012, 06:32 PM
eryk eryk is offline
Vehicle: 01 ram 2500
Trim Level: laramie slt
Rep:13
eryk is on a distinguished road
they are like $60 a piece at autozone
Old 02-29-2012, 12:45 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
They vary by vehicle, I've seen them as cheap as $20 and as expensive as $150. Most fall in the middle somewhere.
Why do you want to replace them? The 2 downstream sensors are likely a different part number than the upstream sensors, also. The 2 upstream sensors are the only ones that would cause a real running issue.
Not to knock mechanics, but many of them don't understand how the system works. Often times it can even not be a faulty O2 sensor but something else making the sensor through a code.
You have a check engine light? What's the code?
Sean
Old 03-01-2012, 11:19 AM
Color: Grey
Rep:27
Talking O2
I have a code "0300" which is "random misfire" which tells me nothing. The truck runs good but every once in awhile it will drop a couple of cylinders, the check engine light starts flashing and it sets the code. You drive it and it will suddenly fix itself. So, I heard that a bad O2 sensor can do this so maybe I'll just change the 2 upstream ones.
Thanks for the info.
Mad
Old 03-01-2012, 11:21 AM
snrusnak's Avatar
Rep:1385
I highly doubt that's a faulty O2 sensor. Sounds like a pcm since it's random.
Sean
Old 03-01-2012, 11:44 AM
Color: Grey
Rep:27
But, if it was a coil wouldn't it throw a code for the cylinder that was misfiring? Not a random code.
Old 03-01-2012, 11:45 AM
snrusnak's Avatar
Rep:1385
Yeah that's why I edited my post after thinking more about it, I don't believe it could be a coil. More likely pcm. I have never heard of an O2 sensor causing a misfire.
Sean
Old 03-06-2012, 08:02 AM
snrusnak's Avatar
Rep:1385
Did you figure this out?
Sean
Old 03-06-2012, 11:55 AM
Color: Grey
Rep:27
Talking Well..
I had the oil and spark plugs changed, he read the codes and cleared it. and told me to drive a specific time at specific speeds and come back to the shop. All is good so far and it easily passed smog. So, I guess I wait until something goes bad enough to stay bad. I am going to change the upstream o2 sensors.
Thanks for the help!
Mad
