Old 04-26-2012, 03:04 AM
azsnow's Avatar
azsnow azsnow is offline
Trim Level: TRX4
azsnow is on a distinguished road
I have tis issue and just thought it was a normal Hemi tick! I will be going to the dealership to see what they say about it.
"Its ok, cause balloon boys dad is in jail!"-Ned from BBTLS
Old 04-26-2012, 12:20 PM
Bodydoc2002's Avatar
Bodydoc2002 Bodydoc2002 is offline
Vehicle: 2009 Dodge Ram 1500
Rep:138
Bodydoc2002 will become famous soon enoughBodydoc2002 will become famous soon enough
I have the same issue. It's at the dealership now i'll report back what they say...
2009 2WD Ram 1500. 7 inch CST Lift. 35 inch Mickey Thompson BAJA ATV. 20 inch ATX Artillery wheels. TOFF Spray in Bed liner. N-Fab 6 step Nerf Bars. BushWacker Pocket/Painted Fender Flairs. Diablosport Predator. K&N CAI 77 Series. 180 Thermostat. LED Tailgate lights.
Old 04-26-2012, 12:33 PM
bigred0311's Avatar
bigred0311 bigred0311 is offline
Vehicle: 2010 Ram Crew Cab 2wd
Trim Level: Big Horn Edition
Color: Off White
Rep:50
bigred0311 will become famous soon enough
is this only an issue for the 2009's? what about the 2010's?
My Build Thread- http://ramforumz.com/showthread.php?p=781468#post781468
Old 04-26-2012, 12:57 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Originally Posted by RamHemi55 View Post
Hello everyone,
This is a pretty important subject clearly because of how unhappy I am with dodge. Have owned 3 rams, my brother has had 4, even my sister owns a Dakota. The issue is on the 09 1500's, there is a pretty big issue with the exhaust manifold bolts. They have a issue with breaking off either at the head of the bolt or inside the motor. This is a problem with my truck and a problem with a friends truck (same as mine). I have seen many posts on this subject not only on this forum but a few others. My truck was in for a bad shift solenoid and they said i have 4 that are broken and i can tell cause i can hear the ticking. $800 dollars to replace all of them with the new style bolts. Dodge is aware of this issue because they have come out with a new style bolt to replace it. My powertrain warranty does not cover this part on my truck so im in a bit of hot water. I called dodge corp today and talked with someone about it and they say there is no "known issue" with this, even though every dealership has received a letter about this from dodge that if its a problem replace it, if not leave it alone. I have 4 dealerships that are on board with this that they will let dodge call them and tell them how many times they have seen this issue. WHAT I NEED FROM ALL OF YOU is if this is an issue with your own vehicle or someones vehicle that you know of, i need you to post up about it on this blog. I will be forwarding this blog to the tech at dodge corp to let him see how much of a problem this is. I refuse to pay 800 dollars out of my own pocket for a part they decided to go cheap on and is breaking yet for some reason they will not put a recall out about. If i can get enough support they will put it out as a recall and they can be replaced not only for me but for everyone else. PLEASE HELP EVERYONE!!!!
The more support for this the closer to a solution we can receive.
Either get some warranty work done or go up to home depo and spend 10 bucks on some new bolts or just get the replacements from the dealership and fix it for free yourself... Or just buy some after market headers...
This has been a known issue since early 2010...
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 04-26-2012, 05:52 PM
azsnow's Avatar
Trim Level: TRX4
Just scheduled an appointment at the dealership, they want me to leave it overnight so they can hear the ticking. There has been numerous little issues with this truck, and if I had to do it again, knowing what I know I would have probably got another GMC instead.
Old 04-26-2012, 06:20 PM
08blackhemiram's Avatar
08blackhemiram 08blackhemiram is offline
Vehicle: 2012 RAM R/T
Color: True Blue Pearl
Rep:27
08blackhemiram is on a distinguished road
just happen on my uncles 09 last week dealer covered it under the lifetime warrenty
Old 05-03-2012, 06:07 PM
ITSARAM's Avatar
ITSARAM ITSARAM is offline
Trim Level: TRX-4
Color: Detonator Yellow
ITSARAM is on a distinguished road
I bought my truck in September of 09. In early 2010 I took it to the dealer for something minor and the service writer told me there was a recall on the exhaust manifold bolts.
They had to order the bolts and when they came in, (2 days later) I dropped the truck off and it was finished in less than 2 hours.
Old 05-21-2012, 11:02 PM
Ramguy65's Avatar
Ramguy65 Ramguy65 is offline
Vehicle: 2014 Dodge Ram Sport
Rep:50
Ramguy65 will become famous soon enough
I had my truck in to replace two of my manifold bolts around 8 months ago. It was covered under the TSB. Didn't cost me a penny. Just recently I started hearing the ticking again and I am sure another bolt or two have broken. I am taking it in this weekend. I will post again when I find out if it is the same problem.
2014 Ram 1500 Sport QC
Hemi, 3.92, Mopar Side Steps, Hemi Mud Flaps, Bakflip F1 Tonneau Cover, BT Catch Can, Magnaflow True Dual Catback Exhaust
Old 05-27-2012, 12:04 PM
popeyesram popeyesram is offline
popeyesram is on a distinguished road
I will be taking my 09 in, hopefully next week for the ticking issue as well. I never heard it when I bought the truck but it was fairly warm out at the time. It has been cooler since then and I have noticed the ticking. Will be pushing for a warranty fix after reading everyone's posts on here. Thanks!!!
Old 05-27-2012, 03:16 PM
Ramguy65's Avatar
Rep:50
I took my truck in for the ticking and sure enough 2 more bolts broke on me and my manifold gasket blew out the back of the manifold. Didn't cost me anything as it was covered under the TSB.
