Old 12-14-2012, 11:24 AM
lrh900 lrh900 is offline
Vehicle: 2009 Dodge Ram 1500
lrh900 is on a distinguished road
I just called my dealer after reading this thread last night. I figured this would have to be an emissions related fix. I found out no, it is power train so it is not covered. I will be taking this to my private shop guy and having him do the work. I just bought this 3 months ago, I love the truck ride great has good power. It has been ticking on cold start since I purchased it, maybe I can get the dealer I bought it form to fix it. Other wise I'll be paying to have the bad designed bolts removed and replaced.
Lonnie
Old 12-17-2012, 04:18 PM
09dodge 09dodge is offline
Vehicle: 2009 dodge ram 1500
Trim Level: STL
09dodge is on a distinguished road
i just got mine back from the shop on friday afternoon.
im not happy with the fact that this is such a common problem and Dodge wont cover it under a recall.
not the best time to be sending $560 to fix the truck just before Christmas
Old 12-17-2012, 04:38 PM
Arth's Avatar
Arth Arth is online now
Color: Mineral Gray Metallic
Rep:2028
Was that all the bolts?
If not how many and what was done?
Chrome... in moderation.
Old 12-18-2012, 01:40 PM
Trim Level: STL
They just replaced one bolt on the passenger side manifold that broke off.
Old 12-18-2012, 03:32 PM
Charlie6k Charlie6k is offline
Vehicle: 2009 Ram 1500 4x4 4door
Trim Level: lariat
Color: Stone White
Charlie6k is on a distinguished road
I had 3 repalced at 24k miles, warranty covered em. Known issue. Very surprised they wont cover !!
Old 12-18-2012, 05:35 PM
Trim Level: STL
im sure they would have covered it if i was still under the original warranty but my truck has 123,500KM on it and my extended warranty wont cover it because the extended warranty wont cover a none lubricated bolt.
trust me i call everything i could think of trying to figure out why this wasnt covered since it was such a common problem and there is a RRT (Rapid Response Transmittal) out for this problem.
all i was told was, under my VIN number, there are no recalls or RRT and that i was SOL.
Old 12-19-2012, 09:13 PM
Taylor15835's Avatar
Taylor15835 Taylor15835 is offline
Vehicle: 2010 ram 1500 sport
Trim Level: sport
Taylor15835 is on a distinguished road
my truck is a 2010 and i have 2 broken, i go in to dodge an they tell me they don't here the exhaust leak and tell me nothing is wrong until i climb under the truck take a picture of the broken bolt and show it to them. now they tell me to make an appointment to have them look at it an see what wrong.... i know what wrong the bolt is broken make me an appointment to fix it not look at it. they piss me off sometimes.
Old 12-19-2012, 09:59 PM
Rep:2642
I guess that i will have to dig up the RRT, TSB, CSN, or whatever it was on those bolts
i am sure that i posted it somewhere in this post, if it was not a SAFETY RELATED problem, you can't force them to fix it
By the way, in the HELP section, there is a STICKY with most every RRT
just click on the RAMS image at the top of every page, it takes you to the REST of this RamforumZ
RRT 10-009 ENGINE TICK NOISE
Cause P00
30995 RRT 10-009 955 5.7L
unable to perform RRT 10-009
Exhaust Manifold Stud Replacement
parts on back order
this was on my Invoice dated 01 SEPT '10
it was fixed at a later date
here is a list of some TSBs, etc.
Compilation of RRT/TSB IDs
08-007-10 -- (TSB) ECO/Fuel Saver light activation
08-018 -- Engine Controls - TIPM update for ECM PROM update issues
08-071 -- Flash cluster for odometer issue
08-077 -- SIRIUS inop due to initial subscription set to less than 1 yr.
08-081 -- Crew cabs w/ sunroof; sunroof drain tubes
08-093 -- Non-memory power pedals won't adjust. Restore vehicle configuration through TIPM
08-100 -- Replace muffler; only factory duals w/ "quiet" muffler
08-101 -- Inspect tailgate cap for warping or loose; replace if needed
09-004 -- PCM flash for spark knock 1800-2500 rpm and/or NVH improvements in MDS
09-010 -- Washer sensor weepage; replace washer harness w/ overlay
09-011 -- Inspect ram box lids for warping; replace if needed (come pre-painted)
09-018 -- Flash RER radio for update
09-020 -- Zip tie rear axle vent tube to frame for possible hanging down
09-023 -- Flash park assist module
09-024 -- Lube passenger seat rail or whatever (for creaking)
09-029 -- Inspect for hood squeak
09-035 -- Tailgate cover (taping)
09-041 -- 2009 DS flash ABS/ESP module
09-063 -- 2009 DS; rambox lock replacement
09-084 -- Replace hood ajar switch
09-095 -- Inspect window molding
09-096 -- Lens lamp, high mounted stop lamp; replaced lense
10-009 -- Replace exhaust manifold bolts
10-020 --
10-022 --
10-028 --
10-029 -- Replace axle disconnect seal
10-061 --
10-083 --
11-019 --
11-047 --
11-057 --
14-001 -- Fuel system - Difficult fuel fill/nozzle shuts off
18-019 -- Engine Controls - MIL on/multiple DTC's set
22-001 -- Wheel shake/tire flat spot
22-002 -- Wheels/Tires - Chrome clad wheel balancing information
26-001 -- Maintenance - Fluid flushing information
RECALLS:
J-10 -- Wiper Motor Replacement
L-04 -- Outer Tie rod Ends
go to this site
http://www.ramtrucks.com/webselfserv...ucks/index.jsp
look for
I need RECALL OR CUSTOMER SATISFACTION NOTIFICATION INFORMATION.
follow the prompts
Old 12-28-2012, 01:28 AM
mattlang mattlang is offline
mattlang is on a distinguished road
Default Add me to the list
mine is so loud when i start it people walk away from it... my dealer in everett has the reply... what hemi tick... never heard of it... and or/ that is normal!
Old 12-28-2012, 09:07 AM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
That's easy; tell them you will pay to have it properly inspected, and it if they find a broken bolt or cracked header ( which it sounds like you have have) they are going to pay to fix it....and if it's under a warranty, you a will pay nothing. Mine sounds like a new truck after I had my manifold and broken bolts replaced. There is no tick anymore
