Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 02-27-2012, 06:34 PM
tdub2112's Avatar
tdub2112 tdub2112 is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:16
tdub2112 is on a distinguished road
Default Hauling a Slide-in Camper
Hey guys, looking to get a slide in camper, but my only problem is my little half ton. We've talked about a Cummins upgrade, but that's a bit out of our price range right now, so it looks like we're going to beef up the 1500.
First off, I'm thinking of throwing a helper spring and some airbags under the rear axle. I've heard people say to only do one at a time, but none have really given a good explanation. I think that if you only had the bags inflated when you're towing for that short distance, you wouldn't have very many problems, but I'm not sure. It sounds like it's more of a comfort thing.
Next, I'm looking into a S&B intake, a Summit Racing 3" exhaust, and a Superchips programmer (unless the new Edge would work on my truck, but that questions is in another thread)
So broken down the cost is roughly $1300. But, the truck will be puting out roughly 300 hp and 450 ft/lbs, which is pretty sweet in my book. I'm a little conserned about the tranny handling that. I've had no problmes so far going stock, but power increases scare me a bit.
To recap in case you skimmed,
-What do you think would help the truck out in hauling a slide in camper?
-If i hopped up the 5.9, do you think I'd have some transmission issues?
Thanks all!
Old 02-27-2012, 06:47 PM
Rep:2705
I can't help you with the power upgrades
I will point you in the direction of one of this sites sponsors
Total Load Control
their contact person is TLC John
mention the RamforumZ
Old 02-27-2012, 09:10 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
What size camper are you looking to haul? I had an 11.5' Jayco Jay Hunter that went in my 96 2500 Cummins Ram. I had the 5000lbs AirLift bags in that. Their max recommended pressure is 100 psi and I would have to put 85-90 psi in them to level that camper even in a 2500 truck. I'm not sure what the specs were for that camper but I bet it was easily over 2500 lbs.
Old 02-27-2012, 09:15 PM
GearHd6's Avatar
Color: Mineral Gray
As far as your helper spring question, if I recall, the AirLift instructions specifically say to remove the factory Add a Leaf if so equipped.
Old 02-29-2012, 02:20 AM
tdub2112's Avatar
Rep:16
We wouldn't need a very big camper. Most of the one's I've found are 1800-2200lbs.
quite a few years ago when i was knee high to a . . . well you get the point. My grandpa would haul an old Lance camper that was 9 feet (if my dad is remembering right) and with a set of airbags it rode just fine in his early 90's F-150. I think if we tried to keep the thing as light as possible we'd be okay.
Thanks for the input! Keep it coming!
Anyone have a half ton that they haul a slide in camper with?
Old 08-05-2012, 11:58 PM
97318 97318 is offline
Vehicle: 1997 Ram 1500
Color: Green
97318 is on a distinguished road
Default how did you make out with your 1500 sliding in that camper
any other 1500 folks reworked your suspensions to accomodate? I'm thinking about a similar rig with my 97 5.2L.
Any input valuable, thanks
Old 08-27-2012, 09:12 PM
Blackhardt's Avatar
Blackhardt Blackhardt is offline
Vehicle: 1998 Dodge Ram 2500
Color: White/Silver
Blackhardt is on a distinguished road
Default Why not look at Popup Slide In
Ahhh a subject I can help with. I had a the last camper i had was a Short Bed Pop Up on my 1/2 ton. It had a dry weight of 1200 / wet weight was about 1650. Palamino and 4 Wheel Camper both have 1/2 ton campers.
4 Wheel Campers - http://www.fourwheelcampers.com/ you can customize to your hearts content. have seen basic setups weighing less than 1000#.
Best of luck....
