Old 02-27-2012, 06:57 PM
DenDen's Avatar
DenDen DenDen is offline
Vehicle: 2011 ram 1500 4x4
Color: Hunter Green
DenDen is on a distinguished road
Default Recirculation button
When I press the recirculation button for the heater,it just flashes then goes out.Is it an option I didnt get or what could it be?Its been like that since new.
2011 Dodge Ram.Hunter Green Crew Cab,Hemi.20 inch wheels.Bought August 28 2011.
Old 02-27-2012, 07:01 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
mine does the same thing, I never gave much thought to it
2011 Big Horn 4x4 -SnowWhite-
Old 02-27-2012, 07:04 PM
Pony Hauler's Avatar
Pony Hauler Pony Hauler is offline
Vehicle: 2011 Ram 1500
Color: Saddle Brown
Pony Hauler is on a distinguished road
I believe that is only for the AC. Have you tried it while running the AC?
Old 02-27-2012, 07:59 PM
Rough 01 Rough 01 is offline
Vehicle: 2011 Ram 1500 Sport
Trim Level: Sport Quad Cab
Rep:67
Rough 01 will become famous soon enough
The issue is (and someone correct me if I'm wrong) that the re-circulation button only works when you're not sending air to the defroster vents. I usually have to adjust it so it is going out the dash, dash/floor or floor vents for that button to work. This is through trial and error so it may be more (or less) complicated than that.
Old 02-27-2012, 08:14 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
You are correct. If you have the defrosters on it will not re-circulate. The light will just flash at u. I think this is one thing they should fix. When it's in auto, full auto. The re-circulate should automatically adjust the settings.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 02-28-2012, 12:28 AM
DenDen's Avatar
Color: Hunter Green
Thanks guys I tried it without defrost and it stayed on.Thought I had tried everything before.
Old 02-28-2012, 05:53 PM
micar71 micar71 is offline
micar71 is on a distinguished road
There is a half moon shaped shroud that pivots over the intake fan located behind the lower glove box. When you select re-circulate, the shroud adjusts it self back from the intake fan so as to minimize the amount of outside air directed in to the fan and allows more cabin air to re-circulate back in to intake.
I'm sure you have already noticed that these are not the most powerful blowers. When you set it for re-circulate, you are telling it to position the shroud so that it sucks air from behind a dashboard console which is restrictive. I don't live in up there so I don't have to resort to setting my heater on this setting. Only the A/C during the summer.
Turn up your blower to high, set it to recirculate, climb in to the passenger side and stick your head below the glove box and listen. Pull your lower glove box and you'll see what I described.
I agree with the others. This is something that should be improved.... in addition to a better blower.
