Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 02-27-2012, 08:46 PM
Dburgos88 Dburgos88 is offline
Vehicle: 2008 Dodge Ram
Dburgos88 is on a distinguished road
Default Trying to lower truck
Want to lower my truck with a 2-4 kit.
What kit do y'all recommend??
I also have 26" rims on it.
Old 02-27-2012, 09:04 PM
Bennett15's Avatar
Bennett15 Bennett15 is offline
Vehicle: 2006 dodge ram 1500 big horn
Trim Level: SLT big horn
Rep:45
Bennett15 is on a distinguished road
Is your truck 2wd or 4wd?
And with 26's you may run into some rubbing issues depending on how big
Of profile your tires are.
I am currently lowering mine on 24s with the groundforce 2"/4" kit.
5% tint, 35% Windshield, Airaid intake, Super 44 exhaust, DiabloSport inTune, 24" Strada Wheels, Bakflip G2 tonneau, Groundforce 2/4 lowering kit, Bilstein shocks, Roll pan, Upper and Lower Eylids, Cross drilled rotors, LED interior, 12k Headlight/Fog HIDs, Recon Tailights, Kenwood Navi deck
Old 02-27-2012, 09:17 PM
It's a 2wd.
Tires are 295/30/26
If it rubes any in the front can I just take out that plastic inner fender??
Old 02-27-2012, 09:39 PM
I push the skinny pedal
Rep:3277
With a 2wd you have lots of options. McGaughy's is probably the best, but there are several others out there for a similar price. A 2/4 will be tight with a 30 series tire (33" tire should be fine, but the 11.21 width may be the issue), you'll most likely need to roll your front inner fender, and the back will clear with no problems. It's unlikely it will be the plastic liner that you'll rub on, more potential for the control arm, but it depends on what your backspacing is like. You can remove the plastic liner, but then you will be filling your engine bay with road grime, extra water, and every little thing that you drive over. I'd say just cut out the offending spot and you'll be fine.
If you want the best bet of fitting with no rubbing then I'd advise just doing drop coils on the front; you'll have more potential clearance issues if you use a drop spindle.
Kurtis
Old 02-28-2012, 07:16 AM
Thanks cdnoilram.
So coils in the front and flip kit in the back?
