tonneaucovered.com
Old 02-28-2012, 12:21 AM
Ram2300 Ram2300 is offline
Vehicle: 2011 dodge ram 1500
Ram2300 is on a distinguished road
Default Electronic light weight engine fans??????
Is there any company that makes a dual electric fan for my truck? I heard by swapping the electric fan with the stock crank fan that I will get a little more power and gas mileage plus the engine works less hard? Is this true and is it worth the swap?
Old 02-28-2012, 07:05 PM
micar71 micar71 is offline
Vehicle: 2011 Dodge Ram
micar71 is on a distinguished road
When the clutch on the fan engages, then the engine is actually working the fan at power/force. The old off set metal fans really sucked the power out of it. The current light weight fans are considerably better.
Get on Amazon.com, go to the automotive section. search accessories and you'll find what you are looking for from different manufacturers. It will even make sure it fits your truck before you attempt to order it.
I live in Texas, where it gets HOT! Honestly, I haven't really noticed when the fan clutch engages, but then again, the A/C is blasting pretty loud. I'm not sure if it would help to much with gas mileage.
Old 03-02-2012, 11:49 AM
Ram2300, are you pulling or planning to pull a trailer. If so, then I would consider it? Search this forum and you will see there are plenty of knowledge (...and personal opinions) on this matter. I would start with the mods catagory and work from there.
GOOD LUCK
