Old 02-29-2012, 12:18 AM
shaun M's Avatar
shaun M shaun M is offline
Vehicle: 1998 dodge ram sport
Trim Level: sport
Rep:20
shaun M is on a distinguished road
Sounds like the intake gasket is leaking at the back of the engine. This is a common issue with the 5.9.
I changed the gasket and installed Hughes plate. Mine isn't as bad as it was when i bought it though.
Old 02-29-2012, 12:29 AM
Rep:2657
I don't know if will work for you
An old trick to find a vacuum leak is to start your vehicle & let it idle, then lightly spray some WD-40 in short squirts, around any place that may be sucking air, when it finds the leak, it will either rev the motor or make it sputter
Personally i think that i would try some SEA FOAM Treatment in the throttle body & the gas tank only
It could also be something wrong with the Drive by wire system
charcoal canister
gas cap, check it first, a bad gasket will do strange things
throttle position sensor
etc.
Good Luck
Old 02-29-2012, 05:34 PM
lowlife28 lowlife28 is offline
Vehicle: 1999 dodge ram 1500 5.9
lowlife28 is on a distinguished road
i replaced when i took my throttle body off to clean it
