Big 3 upgrade? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-04-2012, 08:27 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Any bolt will work. as long as its to a metal thing (duh!) lol
It is better to ground things at the battery, but the battery grounds itself to the fender just behind the battery. (look at my pictures)
I cant stress this enough when people are doing these mods. YOU ARE NOT REPLACING WIRE YOU ARE ADDING ADDITIONAL ELECTRICAL PATHS.
I just think its important everyone knows that haha
2011 Big Horn 4x4 -SnowWhite-
Old 03-05-2012, 12:11 AM
Vehicle: 2012 Dodge Ram Sport
Rep:47
Lol. I really need to do mine. The PDX is causing my evic to dim pretty bad.
Old 12-19-2012, 04:17 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
any more or different input for a 2nd gen 2001 ram sport? I have subs that make my headlights dim already. And im getting LEDs and projector headlights, so i think the big three might be a great idea. haha thanks.
Green Interior LEDs
Old 12-19-2012, 10:36 PM
Rep:47
Nope same wires to same locations.
Old 12-19-2012, 10:49 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
You guys aren't removing the fusible link between the alternator and the PDC...are you?
'cause, that's bad, mmkay?
Old 06-15-2014, 10:31 PM
topsub topsub is offline
Vehicle: 2012 Dodge Ram Laramie
Color: Blue
Rep:156
topsub has a spectacular aura abouttopsub has a spectacular aura about
When doing this do we need to run a power wire to the fuse block?
Sorry to bring up old thread, but good information?
2016 F250 Lariet FX4 CrewCab 6.7L
2012 Dodge Laramie 4x4 CrewCab Supercharged and Lifted - SOLD
My Build Progress
Old 06-16-2014, 09:47 AM
Rep:3347
No, your factory wiring is sufficient to supply the power to the fuse block and any accessories attached to it. Any major draw accessories should be connected with relays, separate circuits, or an auxiliary fuse block.
Old 06-18-2014, 04:13 PM
Color: Blue
Rep:156
Thanks! Waiting on some heat shrink from parts express then i can start the big 3 upgrade. And the better solder, I am having no luck with 'electric solder' from home depot. Not melting what so ever unless i put it right on the soldering iron.
My Build Progress
Old 06-18-2014, 07:04 PM
Rep:3347
If you're going to solder, then I'd pick up solder slugs from somewhere like Acklands. Depending on the cable gauge you're using you'll actually need to put the connector into a vice and heat the connector with a pencil torch to get it hot enough to melt the solder then insert the cable into it and then it'll wick into the cable. I personally just ordered a 10ton hydraulic crimper off Amazon and it worked like a charm, and a crimped connection is a better mechanical connection compared to a solder connection which is better for high vibration areas, like a vehicle.
Are you using a soldering iron or a soldering gun? An iron will rarely make enough heat with a larger gauge cable to get the solder to wick into the parts and you'll only have a cold solder joint which is weak, brittle, and poorly conducts electricity.
Old 06-18-2014, 07:42 PM
Color: Blue
Rep:156
I did buy a torch but i did crimp one connection and put solder on the top side to try and have 'best of both worlds' but not sure how effective it is. The solder i have i am not a fan of and waiting from some of the Cardas Quad-Eutectic solder i bought to get here.
My Build Progress
