Engine misfire with ticking noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-28-2012, 10:35 PM
byrdman1955 byrdman1955 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn 4 x 4
byrdman1955 is on a distinguished road
Unhappy Engine misfire with ticking noise
I have a 2009 Dodge Ram Hemi with 253,000 miles on it. Last week I started to get a ticking noise from the motor. The engine code returned was a misfire cylinder 5 (P0305). It seems that #5 is not firing, and after a few moments, the computer shuts the fuel injector off to this cylinder.
My mechanic has removed the valve cover, the valve springs are ok, the rocker arm appears to be operating normally. He swapped plugs and coil packs, all to no avail. The compression is good in the engine. The noise appears to be coming from the upper part of the motor.
We called the local Dodge dealer and they don't have a clue. If anyone has run into a similar problem, any help would be greatly appreciated.
Old 02-28-2012, 11:59 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Assuming that he checked all of these possibilities thoroughly...is the ticking noise appearing after the injectors are shut off or before? Has he inspected the injectors...253,000 miles...that's a lot of potatoes!
Old 02-29-2012, 06:46 AM
The ticking noise is there as soon as you start the engine and remains the whole time. It is possible the ticking noise and the misfire are two separate issues. I did not know that the misfire code existed until I took the truck in to check it out for the noise.
He is going to pull the rail and see how much fuel is spraying from the injectors. As far as the mileage, I have taken a 95 Dakota w/318 and 02 Dakota w/3.9 to 500K with no internal engine issues ... I travel 90% highway miles and keep my maintenance on a regular schedule.
Old 03-03-2012, 11:48 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
253,000....that's like 85k a year....you making trips around the world?? when I left for Korea my truck had just shy of 25k
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT CAI, custom tune, custom exhaust
Old 03-04-2012, 07:30 AM
I escort oversize loads (yellow flashing lights). The yearly average mileage is usually 100K per year, of which about 90% are highway miles. We have been unable to find anyone who has any idea at this time what the problem could definitely be. In order to save on downtime, I am going to have a used engine installed. Then, if possible, we will have the old engine tore down, see what the malfunction was, and possibly do a complete rebuild on it. I will post what we find out. As you know, 2009 is the 1st year on the 4th Generation Hemi and even Jasper doesn't have any yet. They are currently only up to 2008.
Old 03-04-2012, 07:35 AM
jc4041's Avatar
Rep:146
escorting makes perfect sense lol. I know they were having issues with the '09s and the manifold bolts breaking, they just replaced 2 of mine a couple weeks ago when the wife took it in for the death wobble that developed after they did the tie rod recall
Old 03-04-2012, 09:49 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
my dads old durango sounded just like this. It might not have been a hemi, but it was a bad EGR valve, a bad coil that was arcing and broken manifold bolts. Fixe those and it was quiet as new
2011 Big Horn 4x4 -SnowWhite-
Old 03-07-2012, 04:26 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
I would emagine at 253k that motor needs an overhaul but who know... i dont know what the service history is on this but even if it was well taken care of i would just take it in to a dealer....
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 03-09-2012, 11:04 AM
I have found a used 2009 Hemi with only 41,000 miles on it. After the engine swap, we will be tearing the old engine down and see what happened. Afterwards, we will most likely rebuild the engine. I will update this post as to what we found in the old engine. Like I mentioned before, I have taken 2 Dodges ('95 318 Dakota and '02 3.9 Dakota) to the half million mile mark without ever getting into the engine for anything.
Old 03-14-2012, 08:18 PM
I now know what happened to the engine. The roller on one of the lifters seized, damaging the cam. I think I made the right choice to replace with a used motor, seeing how the old engine would need a complete rebuild and the parts are currently only available from Chrysler until later this year.
