Old 02-29-2012, 01:50 AM
01Ram 01Ram is offline
Vehicle: 2001 Dodge Ram 1500 5.9
01Ram is on a distinguished road
Default 01 Ram idles up and down in A.M
When i start my 2001 dodge ram in the morning, its idle goes up and down, from 1000 to 1500 rpms, until warm. Once its warm it idles fine. I've heard it could be the throttle control sensor, idle air control, even a carbeurator problem. anyone know? thanks
Old 02-29-2012, 12:08 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Carbs are a thing of the past. It could be a vacuum leak, intake manifold not sealing right, IAC or TPS. Check the intake manifold bolts, check for vacuum leaks.
Old 02-29-2012, 05:16 PM
dusted72's Avatar
dusted72 dusted72 is offline
Vehicle: 1998 Dodge Ram
Trim Level: SS/T
dusted72 is on a distinguished road
Sounds like the IAC to me. My 98 does the same thing. It does it in the morning on first start. After it runs for a few minutes it idles fine. Take it off and clean it with carb cleaner. Should fix you right up.
Explosions are cool.
Old 03-03-2012, 02:51 AM
Thanks. I'll try cleaning the IAC valve and see where that puts me. Probably just carbon buildup
cold start, idle, morning, surges
