Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 02-29-2012, 09:55 AM
RenTag RenTag is offline
Vehicle: 2003 Dodge Ram 1500
Color: Gray
RenTag is on a distinguished road
Default Leveling Kit
I'm not sure if this is the right area to post this, but I couldn't figure out how to post anywhere else..
My front suspension needs some work and I haven't leveled my truck yet, so I was considering lifting the front to level it out. I haven't researched it much but I did see a kit for about $150.
Has anyone done this? How hard is it to do? and what are the benefits of raising the front instead of lowering the rear??
Old 02-29-2012, 10:20 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
Your truck is torsioned barred youll need nee keys i had it done at a 4x4 shop for 250$ parts and labor seemed to be outta my realm of capabilities and i do most of my own work
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 02-29-2012, 07:22 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
If he has 2wd (I see no where suggesting that it is 2wd or 4wd), a simple pair of spacers will level it out. If you are 4wd, cranking the torsion bars usually gets them level. Either way an alignment is needed after.
I leveled my truck out (2wd) with a Fat Bobs Garage spacer kit. Installing it was a pretty straight forward process and only took an hour and a half or so. Basically this is all you are doing:
-Jack up the truck as far as you can and place on jackstand.
-Remove wheels and calipers/ rotors
-Take shocks out
-Unbolt tie rod end
-Place jack under lower control arm and lift slightly
-Unbolt upper ball joint and seperate
-Lower the jack that you placed under the lower control arm all the way
-Take stock spacer out and place leveling spacer in
-Reverse process-
Thats the short, dirty version for the 2wd. the 4wd is a simple as climbing under and turning a bolt.
This is before:
This is about 2 hours after:
Sure it'll suck, but it'll make you a man
