Old 02-29-2012, 08:11 PM
fitz7603 fitz7603 is offline
Vehicle: 2012 dodge ram
Trim Level: st express
fitz7603 is on a distinguished road
Default cant get oem brake controller
So heres the deal. I recently bought 2012 Ram 1500 5.7 it had factory installed hitch, 7 pin harness and 4 pin. Dealer said he would install for me the intergrated brake controller. Now the problem is the service department said they cant install the oem brake controller the same one that is fitted and comes from the factory because my truck doesnt have the two connectors that are prewired and taped up. My truck only came with one connector so they are telling me I have to get an after market controller with a single connector and it would be screwed to the plastic. Parts guy said he has seen this before and there is no rhyme or reason for it. Sometimes the truck just comes with one connector. This is crap!!! Help!!!
Old 02-29-2012, 10:50 PM
moterhead moterhead is offline
Vehicle: 2012 Dodge Ram
moterhead is on a distinguished road
I also just bought a 2012 Ram 1500 Big Horn, with the same receiver,7 & 4 pin harness. Mine also didn't come with a brake controller, I also ordered one thru my dealer, also to be installed by them. When I went to pick up my Ram, I got the same story, 1 plug, but not 2. They showed me a factory tech bulletin, explaining the problem. It sounded like a common problem.
Has anyone wired up an aftermarket controller on a 2012? Was it complicated? Which one did you use?
It's easier to get forgivness, than it is to get permission.
Old 02-29-2012, 11:50 PM
Hemiblack's Avatar
Hemiblack Hemiblack is offline
Vehicle: 2012 Ram Express Crew Cab 4x4
Hemiblack is on a distinguished road
They do some weird things from the factory don't they. My 2012 came with the factory brake controller and tow package but no hitch. Crazy.
Old 03-01-2012, 07:16 PM
Tom in ct.'s Avatar
Tom in ct. Tom in ct. is offline
Vehicle: 2012 Dodge ram 1500
Trim Level: express
Color: dark cherry red
Tom in ct. is on a distinguished road
I installed an aftermarket controller on my 2012 ram. the controller I used is called a prodigy. I found the plug under the dash to the right side of the steering column. took out an existing screw at the bottom of the dash. installed the bracket works perfect. the plug under the dash is gray and square with 2 corners cut at 45 degrees. Good luck.
Old 03-01-2012, 09:52 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
If you have EVIC, the factory controller is pretty cool. Still, a quality aftermarket will probably be less expensive, and some of them offer all kinds of bells and whistles. I don't have EVIC in my Express, so I got a Tekonsha P3 with a wiring harness that plugs into the factory harness for about $125. This controller has all kinds of doodads and works in any position. I've been using it in a temporary position, as I'm going to mount it in the existing hole for the factory controller. It snaps in and out of a press-in plug so you can stow it somewhere else if you want, but I'm looking forward to installing it cleanly in the OEM hole and just leaving it there.
Old 03-02-2012, 07:39 AM
Ramsail Ramsail is offline
Vehicle: 2012 Ram 1500
Ramsail is on a distinguished road
I have a used tekonsha P-3 from my old truck that I would sell at a reduced price. PM me if interested.
Curt front trailer hitch-Access Lorado tonneau cover-Mopar bed rug-Lund Genesis tailgate seal-Steelcraft black nerf bars-Putco SSR Locker bed rails-and Auto Ventshield bug deflector-Husky Liners Molded Mud Flaps-Thule Roof Rack-Thule Goalpost
Old 03-02-2012, 08:12 AM
Thanks! I nenegotiated the brake controller as part of the deal when I bought the truck with the assumption it would be the intergrated controller. Now they gave me an aftermarket controller mounted near my left knee. It's a nice controller and works fine but I just dont want it mounted where it is. I want it built in.
Old 03-03-2012, 09:28 PM
snkmug snkmug is offline
Rep:13
snkmug is on a distinguished road
you can add the other harness...The missing harness is the power harness only and only needs a positive, negative, and a can bus connection if you want it to show up on the evic. If you look at the factory controller power plug it has four terminals. Only three are used. Search on here there is a thread on how to do it. The correct harness for the plug can be bought on ebay, or from dodge with the correct part number...
Old 03-04-2012, 11:39 AM
Ironsides Ironsides is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Trim Level: SLT Big Horn
Rep:44
Ironsides is on a distinguished road
Actually, it's Canbus +, Canbus -, and a 12V Accessory wire. And Dodge does not sell that harness.
Old 03-04-2012, 12:38 PM
Rep:13
your not buying the harness, just the replacement connector end...and its a easy install by adding three wires, its been done numerous times..The terminal diagram is on here if you search, and you dont even need the connector if you solder wires to the terminals or use small connectors. Still just a power plug, the main wiring is in the gray plug that all the trucks have...Looks like a dodge connector to me, propably the same one used for something else?
http://www.ebay.com/itm/270755017120...84.m1423.l2649
