Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 03-01-2012, 12:03 AM
tomskratch tomskratch is offline
Vehicle: 2002 Ram 1500 2WD 3.7
tomskratch is on a distinguished road
Default Coolant leaking?? From clutch fan???
Looking for some help with a coolant leak on my 2002 3.7L V6 Ram...
As best as I can tell so far, it appears the coolant is coming from the passenger side of the clutch fan. I can't see exactly where its coming from but if I look under the hood from the drivers side I can see moisture inside the clutch fan (dripping down the fan guard) closest to the radiator.
Any ideas on where it may be coming from before I get into it? Where should I be looking?
Thanks
Old 03-01-2012, 08:19 AM
seltzer seltzer is offline
Vehicle: 2009 Dodge QC 4x4
Color: Pearl Black
seltzer is on a distinguished road
My guess would be water pump.
If You Can't Beat Them...Arrange To Have Them Beaten.......George Carlin
Old 03-01-2012, 11:43 PM
The leak is very slow, a small puddle on the garage floor when the truck sat for two days. Since then, I've barely seen a few drops when I pull out from a parking spot. Has me thinking that maybe the reservoir was too full. Isn't there a overflow spot of some kind???
Maybe the water pump or a seal around the water pump based on what else I read...
Old 03-02-2012, 12:03 AM
Rep:3322
If you can see seepage on the motor then it's either the water pump or from the head. Most likely candidate is the water pump gasket because a head issue would show up with a lot more tell tale signs.
