Old 03-09-2012, 05:06 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Originally Posted by colwell707 View Post
Well talk to the people over at comp cams and you were right. Not much for help. Going to try the guys at hughes engines and see what they think.
Hughes will probably have some recommendation. The issue will selecting a cam for these magnum engines is that a majority of the cam manufactures who made cams for the engine never really tested it in an actual magnum engine with the stock ECM. Even to stock replacement at comp for the 5.2L part number 20-608-9, Comp cannot even promise that it will work properly with the 5.2L engine because of the ECM. The ECM is a big issue atleast with stock because the stock ECM cannot be programmed easily if not at all. Another issue is that chrysler experimented with cams on the magnum engines during their lifetime. So the cams in the 5.2L are different in a 93 then a 95 then a 97 then a 03. So it's such a pain in the rear to get dead on balls with a cam, it's really boiling down to trial error.
Great engines, but modifications aren't always easy. Thing I hate the most of all is that their are more mods avail for chevy engine then anything else.
Old 03-12-2012, 12:08 AM
colwell707 colwell707 is offline
Vehicle: 1999 Dodge Ram 1500 4*4 5spd
Color: grey
colwell707 is on a distinguished road
The recommendation was re-degree in the cam to 109*. Also to clean up the ecm with a custom tunes with a SCT tuner.
Old 03-12-2012, 12:58 AM
ramvan2500's Avatar
Rep:128
Try 110 intake, it might be different for your year but from the calculator I made it shoots out 110. I hate how chrysler used so many different cams on the same engine. But the ECM's were different from OBD1, OBD2, and engine OBD3. The magnum covered all 3 amazing...
Anyway's I made a Cam Calculator for excell/openoffice if you want it I'm happy to give it out. Simply you enter in the valve events and it tells you the ICL ECL LSA OVERLAP Durations and how many degrees the cam ground is advanced or retarded when installed dot to dot, in my calculator it allows you to enter in the degree you want and it will tell you the new valve events the new ECL ICL LSA etc... Very fun little calculator
Old 03-12-2012, 01:27 AM
Color: grey
You definately know your stuff! Haha. I'll pass that on to the motor guy thats helping me. I just hate that i have to take the motor back down.
Old 03-12-2012, 05:14 PM
ramvan2500's Avatar
Rep:128
Well it's good to take it out and do it over, better then taking the risk of damaging to engine!
Old 03-12-2012, 09:33 PM
Color: grey
This is very true!
Old 03-12-2012, 11:21 PM
ramvan2500's Avatar
Rep:128
This is very true!
Hey do you want to try the calculator I made? I added some other things to it, now it will allow you to enter in data to figure the vehicles potential speed and it graphs it also, it also will display the torque throughout the entire drivetrain at each gear and graph it also. I really would like someone else to try it then me because I make them so I get bored of them... It works in excell and open office spreadsheet.
Old 03-13-2012, 04:07 AM
Color: grey
Yeah send it to me!
Old 03-13-2012, 11:06 AM
ramvan2500's Avatar
Rep:128
Yeah send it to me!
I attached the file, in order to view it you need to have either open office or you have Office 2007. If you have office 2003 it will work provided you install the compatability pack. Camshaft Timing CalculatorEXC.zip
