Old 03-02-2012, 01:46 AM
m7freak m7freak is offline
Vehicle: 2010 Dodge Ram 2500 CC LB
Trim Level: SLT Big Horn
m7freak is on a distinguished road
Default 2010 Dodge Ram 2500 Steering Wheel moaning noise
Hi, I have a 2010 Dodge Ram 2500 4x4. I had a 5" lift installed on it. After a few months, I noticed that when I turn the wheel to the left the steering wheels tightens and pops and makes a moaning/popping noise....??? Only to the left however.... Truck only has 9000 miles...
Any ideas?
Thanks in advance!!! Mark
Old 03-05-2012, 10:06 AM
RamManCan RamManCan is offline
Vehicle: 2010 Ram
RamManCan is on a distinguished road
The moan sounds like it could be the power steering pump. The popping sounds like a tie rod or something...did the 2500's have the same tie rod recall as the 1500's? You should also check to see if everything is tight. One of our work trucks actually had the power steering pump come loose, it made some funny noises too, and it was only one way too. Is the steering any tighter when the pop happens? Maybe some linkage is binding...I'm not a mechanic so I don't know...but thats where I would start.
