Old 10-17-2012, 07:01 PM
RC DuDe's Avatar
RC DuDe RC DuDe is offline
Vehicle: 2011 Ram 1500
Trim Level: 2WD SLT Crew Cab
RC DuDe is on a distinguished road
Hey Steel, the end links are about 8 1/8 to 8 3/16 long center to center and the panhard bracket is about 4 1/2 center to center below the factory mount. I just laid under there and used a tape measure. Those measurements are pretty accurate but I had clean clothes on and wasn't committed to getting dirty. When I said center it up before tacking the fabbed bracket up I was referring to making sure the outside of the wheels line up with the bed or you'll have one side stick out further than the other.
Belltech will send you modified end links for the swaybar free of charge if you call them. They asked me a bunch of questions and why I thought I needed them. They also asked for a copy of the receipt. I told them about my wobble problem and they sent them without further questions.
I don't have any further dimensions but would be happy to help you through this.
I have 22'' rims with tires that equate to the same outside diameter as my stock rims and tires just wider and heavier. I know that the tire dimensions vary amongst manufacturers but close enough. It bottoms out like MAD everywhere. Even on smooth roads where there are just waves in the asphalt. It bottoms out in the front and back pretty bad. There are ways to fix it but I'm not going to spend anymore on lowering. I just wanted to make it safer. I tow jet skis and load MX bikes on the truck regularly. Have 4-5 passengers regularly and all I can say is that I'm very disappointed. I have assist air bags installed also. I have the longer ones that are listed for our truck took those out and installed shorter ones listed somewhere here in the forums. I can dig that up if needed. Ride is super harsh when pumped up enough to not bottom out and makes the front end bottoms out a lot more. To get the truck to stop pulling to the right even when aligned properly try having the shop adjust the left caster. This won't cause tire wear. Mine did the same thing and this helped.
While I think my truck looks fantastic I'm not happy with this setup.
Good luck.
Old 10-17-2012, 07:24 PM
Steel don Steel don is offline
Vehicle: 2011 1500 Ram
Steel don is on a distinguished road
Rc Dude
thanks for your input.I'm going to start this weekend on bracket.
sad to hear about no hope to improve the bottoming out issue.
I guess I should have done more homework up front.
thanks again
Old 10-24-2012, 12:03 AM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
Not sure if you have seen elsewhere on here yet, But I did a bit of research on a fix for the soft rear end and bottoming out. AIRLIFT 1000 part #60824 fits the dropped ram trucks perfectly. I keep about 8 PSI in mine all the time and it rides great, and will not bottom out. Plus side is you can increase pressure to haul heavier loads.
air line with air fitting mounted on the trailer hitch
Old 10-31-2012, 07:09 PM
PeterGriffin's Avatar
PeterGriffin PeterGriffin is offline
Vehicle: 2011 Ram 1500 Sport 4x4
Color: BLACK
Rep:9
PeterGriffin is an unknown quantity at this point
Originally Posted by Ramfd View Post
That is one handy dog! Can't say I've ever seen one turn a wrench before...
MOPAR trailer brake controller,rubber floor mats & rear view camera*tint*Plastidipped wheels*K&N drop-in*180 thermostat*debadged*running boards DELETED*Front Speakers:Quantum Audio 6-inch*Rear Speakers:Pioneer 6x9*Alpine 4-channel amp*Kenwood Sub amp*Sub:2/10-inch Rockford Fosgate*high/low/fog HIDs
Old 11-02-2012, 01:36 AM
Ramfd's Avatar
Rep:150
best dog i ever had, too bad she does more steeling of the wrenches than turning of them.
Old 11-02-2012, 08:41 AM
Color: BLACK
Rep:9
Thanks for the info on the AirLift too, I'm fixin' on doing a 2/4 drop and tow a little bit so it's gonna be critical to keep things square...
Old 11-02-2012, 05:52 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
Hey guys, please petition BellTech via email to make a panhard relocation bracket for their kits! It would make a HUGE difference in the handling characteristics of your trucks when lowered! It should have been something provided with the kit when sold, IMO.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 12-28-2012, 12:47 PM
Air lift 1000 is the fix for sure.
Getting trinity tuner installed right now.
Old 01-07-2013, 07:57 PM
jrod1989's Avatar
jrod1989 jrod1989 is offline
Vehicle: 2012 ram r/t
Trim Level: r/t
Color: flame red
jrod1989 is on a distinguished road
I just put the belltech on my r/t and the passenger front was a 1/2 inch lower so I had to call belltech and now they are goin to send me new springs to see if it fixes the problem
Old 01-15-2013, 01:34 PM
GS1320's Avatar
GS1320 GS1320 is offline
Vehicle: 2012 RAM 1500 QC
Color: Mineral Gray Metallic
GS1320 is on a distinguished road
To everyone that has this kit, please keep us updated!
I like cars, and I don't really care where they were made.
panhard bar, panhard rod, track bar, track bar re locator
