Old 03-02-2012, 11:27 AM
blues4u2 blues4u2 is offline
blues4u2 is on a distinguished road
Default Rear end issue
I have a 2010 Dodge Ram 1500 Big Horn Crew Cab. A few weeks ago while driving to work as I approached a stop light my truck started to shake violently, threw her in to netural and it stopped. Found out that the rear end had seized up and the drive shaft literally snapped the bolts off the rear end! I was very fortunate that this did not occur while driving on the highway. I have only had this truck since August of 2010, bought it new. Just wondering if anyone else out there ever exeperienced anything like this with their Ram? I contacted Chrysler and told them that I was not happy about this since the truck is less than two years old and was concerned for myself and my familys safety. Of course they offered no solution as far as vehicle replacment or really any concern for me and my family's safety, but told me that I could pursue this as a safety issue with my State Attorney General's office. Want to know if anyone ever had an issue with this and if so what was your course of action to resolve this issue, if any?
Thanks
Jimi (N.J.)
Old 03-02-2012, 03:26 PM
Liberty Guerrilla Liberty Guerrilla is offline
Vehicle: 2010 Ram 1500 Crew Cab 4X4 SB
Color: Brilliant Black Crystal Pearl Paint
Rep:26
Liberty Guerrilla is on a distinguished road
I personally have not seen or heard this before... You may do an online search and see if there have been any other reports...
You should still have Power-train Warranty right? Is Dodge taking care of the repair?
Old 03-02-2012, 07:01 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
It seems to be very common on these trucks. Do some searching on here and you'll find out others have dropped the driveshafts in the road when the yokes fell off the rearend.
Here is one example: http://www.ramforumz.com/showthread.php?t=101654
2nd: http://www.ramforumz.com/showthread.php?t=100941
Old 03-02-2012, 07:46 PM
Seth's Avatar
Seth Seth is offline
Trim Level: Laramie 4x4
Rep:33
Seth is on a distinguished road
Very same thing happened to me in the middle of an intersection. Had to get towed to the dealer. If you look for other posts by me I give great detail on how the whole thing happened. Apparently this is pretty common. If you have your music up it could catch you totally off guard. Music low or off and you can hear almost like an engine breaking sound before the shaft falls off. 2010 Ram rear ends have not been very reliable. If enough people complain maybe there will be a recall (which should have happened long ago).
MODS: 5" Raptor Nerf Bars, Line-X Spray in Bed Liner & Extang Solid Fold Tonneau Cover
Old 03-03-2012, 12:01 AM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
Some Late 2010's and early 2011's came from the factory low on gear lube. There is a TSB on this I beleive. As soon as I heard this I checked mine and it was an inch below the full plug. These rearends are not as strong as my 04 was. Towing the same trailer caused my 2010 to overheat. I bought a Mag Hytec cooling diff. cover and so far all is well. ( holds 2 qts.more + a magnetic drain plug and a dip stick.)
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 03-04-2012, 07:54 AM
mastertech10 mastertech10 is offline
Vehicle: 2013 RAM 1500
Rep:12
mastertech10 is on a distinguished road
if your rear end really did seize up as you describe then surely there was some loud bearing noise in the weeks/months prior.
or was it the yoke falling off caused by the pinion nut backing off and the diff is ok now?
Old 03-04-2012, 08:47 AM
Evil Ram's Avatar
Evil Ram Evil Ram is offline
Vehicle: 2010 DODGE LARAMIE
Trim Level: laramie
Evil Ram is on a distinguished road
So how would we check to avoid this problem before it happens ?
Old 03-05-2012, 02:54 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
I'm getting mine checked next time I take it to the dealership, which isn't often. That's my question too - if this was a pinion nut backing out, how do you diagnose if it's tight when you take it there? Did they change pinion nuts to fix this problem on trucks where it loosened up?
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 03-05-2012, 04:49 PM
Rep:2705
Once a pinion nut has been used, they don't or are not suppose to reuse it
when a pinion seal starts leaking & is replaced, it is highly recommended that a new pinion nut be used. The nuts threads are torqued on to the pinion bearing & set the pre load on the crush sleeve & therefore the pinion gear itself.
Old 03-05-2012, 09:55 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Color: Burgandy
Rep:160
Being ignorant myself, if I were to have my differential cover replaced with an after-market cover, could the pinion nut be checked at this time? I'm looking forward to a whole season of pulling my TT around, I'd hate like hell to have that back off running down the highway.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ MINI MAX 75 HP TOWING TUNE/ OD TUNE COMING SOON!
