Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 03-02-2012, 01:27 PM
dandk1989 dandk1989 is offline
Vehicle: 2004 1500 Hemi 5.7
Color: Gold
dandk1989 is on a distinguished road
Question leveling kit
Looking to install 2in in leveling coil spacer on my 2500 Cummins. Is there any way to do this from under the truck rather than thru engine compartment. The latter would require removing the brake master cylinder first before pulling the shock up.(at least thats what all the instructions say to do).
Don't want to get involved with brake hydraulics if I could.
Thanks for any advice.
Old 04-18-2012, 11:18 AM
UB40 UB40 is offline
Vehicle: 2008 Dodge Ram 4 door 2whl dr
Color: pewter
UB40 is on a distinguished road
Default leveling kit
I put a similar kit in a 2008 Ram 1500 it can be kind of tricky if it has struts it's easy but if its a coil with a seperate shock like mine is I'd suggest taking it to a shop I had mine put in for $140 that spring can be kind of dangerous.
Old 07-12-2012, 03:45 AM
bcaraway's Avatar
bcaraway bcaraway is offline
Vehicle: 2001 Dodge Ram Sport Off-Road
Trim Level: Sport Off-Road
bcaraway is on a distinguished road
Its actually pretty simple. I just recently changed the springs on my 1500. You will need a hydraulic jack and a couple jack stands. Jack up your truck enough to pull the wheels off and put your jacks under the body, disconnect the sway bar and loosen the bolt on top of the shocks. Now you are ready to lower the axle down, which will loosen the spring tension. You will have to remove the shocks to install the coil spacers, which is a great time to replace your shocks, then you just reverse the process!
Hope this helps!
Old 07-19-2012, 11:50 AM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
I did it on my 2001 Diesel and never removed anything brake related. I have done many of these and never heard that before. The spring either needs compressed or pressure taken off. Once you loosen the shock it can come out where the spring is. Only thing under the hood needed is one back nut that can be done from underneath but easier under hood.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
