My SCT tuner thread - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 04-20-2012, 12:48 PM
augiedoggy's Avatar
augiedoggy augiedoggy is offline
Vehicle: 1996 Dodge ram 1500
Rep:12
augiedoggy is on a distinguished road
Well I sw beeker posted something yesterday....
[IMG]http://***************/forum/images/kirsch/statusicon/post_old.gif[/IMG] 04-18-2012, 01:08 PM
[IMG]http://***************/forum/image.php?u=122659&dateline=1316751669[/IMG] beeker [IMG]http://***************/forum/images/kirsch/statusicon/user_offline.gif[/IMG]
Rookie
2001 Dodge Ram 1500
Vehicle: '01 Ram 1500 4x4 Sport 5.9
[IMG]http://***************/forum/images/icons/icon1.gif[/IMG]
Don't waste your money on a SCT if you are looking for mpg/kpl gains. I have dyno'd on all fuels with and without tune and it doesn't make any noticeable power gains. I am getting 8mpg/3.5kpl in town and get up to 14mpg/6kpl highway. Fix any problems you may have and just accept that the truck is a gas hog. You aren't going to gain much kpl from doing mods. Best thing you can do is cut off factory muffler and max pressure on the tires.
[IMG]http://***************/forum/image.php?u=122659&type=sigpic&dateline=1333002764[/IMG]
Old 04-20-2012, 08:27 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I read his comment which would lead me to believe that he has given up with sean trying to get the last bit of power/mileage out of his truck.
It appears that Sean sets things up on the rich side and is afraid of going to lean.
Old 04-21-2012, 05:57 PM
Trim Level: Fleet
Rep:47
Today was rather interesting....
I went and filled my tank with 91 octane, which is pretty much what you can get for premium in this area.
I noted that my mileage had JUMPED on the last tank. I recorded an IMPRESSIVE 11.4 mpg! Fluke? Or did removing my bug shield drop my drag co efficient?
Anyway, after putting over 21 gallons of hi test in, I loaded in my 93 tune and took and took a test drive.
And then came home and loaded the 89 tune back in. Reason being the dam motor pinged like a &8^%&76798y%%4! So much for that. It may have had a bit more uummmfff down low, but not enough to warrant keeping the tune.
It seemed like the tune was set for about 40 degrees advance that was right now. Not what I would've have done with an old school mechanical distributor.
However, I would be estatic about a consistent 11.4 mpg city mileage, almost a full mpg over my baseline.
Old 04-22-2012, 09:57 AM
augiedoggy's Avatar
Rep:12
Im not gonna say it....
These trucks have a reputation for enough pinging issues with the stock tune..
Old 04-22-2012, 05:15 PM
Trim Level: Fleet
Rep:47
Never had a lick of trouble on 87 with stock tune after fixing my plenum. Even ran the 86 octane found in Texas and New Mexico along the I-40 corridor. Not to say others haven't based on thier PCMs sttings.
Was running 87 on the 89 tune without issues.
Old 04-23-2012, 04:37 PM
augiedoggy's Avatar
Rep:12
well h timg on a stock tune is designed for the 87 octane... and if you have the death flash that changed the timing so it advanced less so it was less likely to ping with 87...
Old 05-25-2012, 09:55 PM
Trim Level: Fleet
Rep:47
I've recorded 11.5 mpg on my last two tanks and thats probably where the mileage will stay. I am happy with the results and know that I could pay for the tuner in about a year based on the mileage savings. If I'd gotten anywhere around 12mpg I'd be estatic.
This summer I'll be taking the Ram to Minnesota and back with a a detour through my old stomping grounds of Eastern Iowa. I will post up with the good, the bad and the average, and then let the thread close.
I appreciate all your comments and suggestions.
Old 06-25-2012, 10:01 PM
Trim Level: Fleet
Rep:47
Well, I finally got down to crunching numbers tonight from my roadtrip.
This was a 9 day adventure up to Minnesota, down to Eastern Iowa, and then home to Okiehoma. Technicaly we were in Illinois for about 40 minutes.
Speeds averaged around 63 mph, the weather was mostly hot and humid so the AC was on. It seems we were always bucking a headwind.
Anyway, the truck survived even if I was a bit stressed. We traveled 1673 miles and burned 130.7 gallons of either 87 regular or 89 ethanol gas.
This averages about 12.8 mpg
GF....the family keeper of records....tells me this is about 1.5 mpg better than the last trip we took in the ram...when gas was also in the 4.10 a gallon range!
She also tells me this was still cheaper then renting an SUV the cost of which would have offset the mileage it wouldv'e gotten.
This was to be my final post, but I may add one more. I exchanged some pms with Sean when I discovered he'd signed on with RF and he ended up sending me a new tune. This tune is still an 89 octane one but is supposed to change the shift point for OD. I believe its supposed to shift sooner. This should improve my "suburban" mileage.
BTW I can't fault Sean for his help and service. He tolerates my dumbest questions and tells me what I need to know.
Old 07-04-2012, 01:58 PM
Trim Level: Fleet
Rep:47
Update:
After discussing OD lockup speeds, Sean sent me a tune that locks up the OD about 40/45 mph. This is similar to factory program.
He also tweaked the tune, and whatever he did increased low end torque to where I can actually spin the tires from a dead stop.
I'm hoping he'll offer this tune as an option or canned version. It's supposed to be hotter than the 87 tune but I'm still running 87 octane gas!
